Could someone help me out with some Instantaneous Voltage calculations please.
I need to calculate the value of the resultant waveform at 45deg 120deg & 240deg that includes a third harmonic content of 20v.
Vmax is 200V, third harmonic amplitude is 20v
I know that to find the instantaneous voltage the calculation is:
e = Vmax sin0
So
e = 200 x sin 45 = 141.4V
e = 200 x sin 120 = 173.2V
e = 200 x sin 240 = -173.2V
Do I just ADD the 20v to each result to include the third harmonic amplitude or is there more to it?
Cheers
e = Vmax sin0
So
Cheers
Its:
e=200*sin(45)+20*sin(45*3)
e=200*sin(120)+20*sin(120*3)
e=200*sin(240)+20*sin(240*3)
Here's a spreadsheet showing the graph of the actual values you're interested in:
View attachment 10percent_3rd_harm.zip
w
I've taken the phase relationship as 0 degrees.
w
Thanks for the replies guy's & also the Excel spreadsheets,
I see how this is calculated, much appreciated.
If I could ask one more question.
How does the phase relationship factor into the equation, could you possibly give me a quick example, basically for future reference.
Thanks Guy's
Cheers
Thanks Guy's
Cheers
The phase relationship causes the voltages to add in different ways. As the waveform changes you will get different results, although the rms will be unchanged.
Just pick a phase and plot it with graph paper, adding the voltages at each instant of time. The wave could be flattened or peaked but will be symmetrical with only odd harmonics.
- General Interest
- Everything Else
- Instantaneous Voltage--Math Question!
