inrush current limiter!
Hello! I have a question about a "Tripp Lite ISOBAR6ULTRA Surge Suppresor".if I have my amp connected to it...should I still need an "Inrush Current Limiting Thermistor" ? How is this one for it http://www.ametherm.com/datasheets/MS35-0R550_datasheet.htm
:smash:I see some people say 12ohm is for 120vac and 24ohm is for 240vac.and other say to use a lower ohms thermistor.I am not so sure witch one is the right one for a gainclone LM3875 using 20000uf per channel with a plitron transformer 22v x 2.I want to use one in the hot line and one in the neutral too(just in case) and is one enough or should I use two in series?.thank you guys.
Hi Anthony,I do not find the ones you suggested 22R x 2 is this for 220v? (one in the Hot and one in the Neutral)on this web.Can you tell me the right one for my amp 120vac using 20000uf per channel and plitron transformer 22x2.I want to go for the safest mode as possible.I see they have the MS series(mega surge).I believe these MS thermistors are better.
How is this one for Hot and one for the neutral.http://www.ametherm.com/datasheets/MS35-10018_datasheet.htm
Any help will be appreciate,Thank you.😀
