Infineon MA12070 Class D
Oh, alright. That's a low, low resistance. Perhaps two 4Ω drivers in parallel.
So I guess it'd be 40W on 8Ω? Right now I have it in stereo mode on a pair of Klipsch Ref IV RF62, which are rated for 125W, and I can tell you it does not sound like a mere 20W at full volume. On the other hand, it doesn't even get luke warm ... the heat sink just stays at room temperature.
Where in the datasheet can I read measurements with PBTL mode? can only find BTL.
10% THD is bad.. but at what point does it reach that levels?
I'm not gonna push it to these levels of course. Just curious about the performance.
If really bad I can just as well use one board in BTL..
Just this in Table 7-1, no detailed measurements.
Thanx.
So,, does this mean that it has TDH 1% at 1Khz with 120W power.
I would love to see real measurements.. specifically when distortion starts to rise..
I,m not sure I ever will use that kind of power for my speakers..
But I,m no expert.. I just heard that these sound fantastic 🙂
Tested quite a few MA12070 boards and the winner is double Chip €30 board fed by
SMSL DL200 differential signal to indicated removed caps
. Skipping active stage is best. Output stage on DL200 has no coupling cap either.
Ugh and ****...I just ordered 3...
This will be perfect for my multichannel dac based on AK4493seq, with unbalanced outputs.
This would perhaps satisfy the nostalgia of my Sabaj A20a, which I sold...
Great find, for the price and seems easy to modify!
