Remote volume control
Hi Peter,
I would like to get a set up like this. I use a Lighter Note LDR single ended pre amp now.I would like to try this to drive a balanced set of ldrs and allow me very tight control of the 4 gangs needed and make a balanced remote controlled Lightspeed LDR preamp. I would need switching of 2 balanced inputs and 2 single ended inputs also. If I dont like it I can revert it back to the ladder resistor set up. I need one!
Hi Peter,
The PEC actually isn't that bad. Mine tracks well up to 12 O'clock.
Only real problem is it's scratchy when turning up the volume.
It sealed, so not sure why it's making noise.
Is there a break-in period with PECs?
Relay-based attenuator
Peter and Veteran,
How did the relay-based attenuator end up sounding?
Brad
Peter and Veteran,
Brad
Perfectly for me. This passive volume control is very neutral. There is only one minus - relays are a little noisy when changing the volume 😉
Well, did it all end here?
Is the perfect attenuator found?
Will it ever surface so we can be able to experience its "second to none" facilities?
