Im newb here need help repairing 2- punch 250a2's
I have a ? I found that the big gate resistor r263 is bad. I thought the only one that was bad was the small surface mount one r20 on power supply. But found this that i thought i already checked. Anyways these are .3 ohm on my amp, the schematic says .1ohm my ? Is are they 3w or 2w and can i substitute a .1 out of my punch 60 dsm thats for parts?
R263 isn't a gate resistor. Gate resistors are the resistors in series with the gate terminal of an FET.
R263 is a source resistor.
With most multimeters, you will see a resistance of about 0.2 ohms when you touch the probes together. Part of this 0.2 ohm reading is the resistance of the leads. When reading low value resistors (like 0.1 or 0.2 ohm emitter/source resistors), you can touch the probes together for a few seconds and subtract that from the value the meter gives you when you measure the resistance across the low value resistor.
Sorry for my ignorance yes it toggles between .4 and .5 when measuring a good one. The 1 in ? Measures up in k range cant remember exactly it has black orange silver gold stripe pretty sure that is .3ohm. If i tried putting a .1 in there would it hurt anything or would i need to replace all of them?
The black, orange... is a 0.03 ohm. The 0.03 and 0.1 aren't interchangeable. The photos I have of a 250a2 have 0.03 ohm resistors.
There are no parallel source resistors so you only need to replace the failed one.
The 0.1 may serve to allow testing at low levels but it's not going to allow the amp to produce full power because it will make the protection circuit much more sensitive.
If the source resistor opened, there may be damage to the protection circuit. Check R261 and R262 while the source resistor is out of the circuit.
Im sorry i misread the color chart. In that case the possible replacement resistor is a .01 ohm. I swear the schematic said .1 on it which i know doesnt match my board #. I will check those other res you mentioned earlier when i get home.
Ok Perry I replaced all known bad components. The ps was replaced with 3205's with 47ohm gates. When powered up the light comes on then about 2 or 3 sec later tmy ps drags down to 8.5v i ammediately pull power what that happens. Is there something i need to check now?
My ps is a pyramid ps-12 12amp
I tried that perry i think the current draw was less voltage dropped just a little and ps started singing a little then i heard what sounded like a static snap. And i seen what looked like a arc from closest cap (c22) from there to heat sink ?
