Joimonf, next ideal bridge will handle 200V @ even higher currents, while been very compact.
Regards,
Tibi
Sounds interesting!
I'm interested too.🙂
Yeah this sounds great:
Hi Jan,
For tube fans I'll have discrete ideal diodes that will handle up to 450V at 6A.
Hope the end of soft tube rectification is near. 😀
Regards,
Tibi
Joined 2009
Who the heck designs tube amps running at 6A 😀
I'd be interested in a solution for tube amps but there are already good reports from plain old diodes made from SiC and at 450V we don't care if we lose a few volts. However, I'm very interested in the soft-start option. I need more than 450V by the way - especially for choke loaded supplies.
Note: soft start is good for tube amps with EI transformers. The SS boys using humongous toroidal transformers need their soft start on the primary because the toroid itself is part of the start-up issue not just the caps. A soft-start on the secondary (as part of rectifier) will not fix their troubles.
I have made a synchronous diode/rectifier design that may work at 1200V @ 30A.
Wonder who need such ? 😀
Regards,
Tibi
Regards,
Tibi
But what about hard tube rectification? These types of comparison would be interesting.
Joined 2009
Regards,
Tibi
Are you offering them for sale, I have a project coming up with a Hamond 714 (510-0-510) power transformer.
Even at higher voltages, synchronous rectification make sense due very low power dissipation, very small and compact circuitry and very low noise. Diode switching noise become very important at higher voltages.
However, that glowing tube has his magic.
Regards,
Tibi
Regards,
Tibi
Joined 2009
with soft start and good diode turn-off behaviour there will never been a reason to use a tube rectifier
of course, you can't go retrofitting anywhere you feel like it - without series resistors the high current pulses of SS diodes will over-heat many transformers designed for tube rectifiers due to I*I*R heating of the copper windings
Btw, do you know if synchronous rectifiers are used in automotive alternators as well? Are there any controller chips available?Synchronous rectification is the next step in audio (and not only audio),
Best regards!
I made this only as an exercise and for fun. Only the mosfet alone is quite expensive. I do not think this will end to have any commercial success.
Regards,
Tibi
Best regards!
Yes, they are and I have designed one too. 😀
Hope will be available on market soon.
Regards,
Tibi
This is to let you know that I'm designing another two ideal bridges.
One will be dedicated to low voltage, small power applications, with very small footprint 6x6 mm and will handle around 8A continuous.
Second one will be able to handle voltages up to 200V and 35-40A continuous.
Synchronous rectification is the next step in audio (and not only audio), it brings sonic improvement in almost any appliance.
Regards,
Tibi
I am interested in acquiring some of these, for Class A amp power supplies in the 25-40 VDC range.
How will these be sold?
Joined 2009
A. Saligny is best here, as will act like a miliohm resistor. Entire transformer power is delivered to load with minimal loss.
In comparison a diode bridge will limit current and power delivered due power high loss over each diode.
You really want to pair this rectifier with a low loss power transformer, one with low DCR. Of course this will result in increased turn-on current but it will reduce the bottleneck if that's important to your project
I've been hearing paraphrases of this for close to 40 years. The results so far have not been encouraging.
Saligny can handle this voltages. GB was closed. If there is enough interest ( I mean over 100 units ) I may run another GB.
Regards,
Tibi
This is a turn-on issue and the aim of ideal rectification is not to solve such problem. There are dedicated simple circuits that address turn-on.
Regards,
Tibi
Hi Tibi,Yes, they are and I have designed one too. 😀
I'd be interested in synchronous rectifiers for the alternators in my old BMW flat twin airhead motorcycles 😉.
Best regards!
I may be interested as well.
Regards,
Dan
- Group Buys
- Ideal bridge rectifier GB
