ICEPower 50ASX2 plays then goes into Protection
Hello Frobek,.... good job with IcePower 50asx2 amplifier solution !!! ....I have a doubt and I need your help, now I have another brick on the bench......haha......my Icepower 50asx2 have the same symtom, I have already removed the silicon and I have discovered the resistors two of 62K (one it's ok other is broken) but the others that you say as resistors it don't have code and color is blue, one of these measures 5K and other is open..... but seems to be both is a capacitors ....really are resistors smd 5K ???......Thanks in advance.
Ok, thanks !!, I have other quiestion...., do you know if a IcePower 50asx2 stereo config it's possible convert to BTL config changing only the bridge W401 to W400 or requires some other changes ???.........Thanks in advance.
Yes, but you do have to have a bridge converter to feed the two inputs with anti-phase signals. I did this for my bass practice combo amp. I have read on here that there is a resistor change that does make the SE a BTL, but I have no problem just bridging the amp.
Hello Chienmort, sure !! This change is for my Rumble 200 Fender bass combo, this amp have a preamp with output anti-phase signals for connection to ICE BTL amp, now I have done the bridge connection from SE to BTL and works fine....Thanks !!!
I know this is a old post, but was wondering if this same thing is my issue with a icpower1200as2? I get the same ON/OFF-standby switching on my module. Any suggestions? I think I will try my variac and see if this stops when the voltage is lowered. Thanks
@frobek
I see that you have solved the issue with the 50ASX2 amp, But I have the 1200as2 and having the same issue. I tried plugging it into my Variac and set the voltage around 92V, and it works great. But when the voltage is higher, it continues to switch ON-Standby modes. Any recommendations would be greatly appreciated! Thanks
Now this topic is REALLY old….
I can’t locate ICC1…
I’ve scraped off the glue to reveal the resistors, but don’t know which pin 1 & pin 2 to check the +1.85 & -1.85V as mentioned above by frobek. I don’t want to attempt to replace those resistors if they’re not the problem. (How the heck do you solder those teeny things anyway?)
Picture of my board attached.
BTW, I finally identified which component is ICC1
The fault: When I turned my amp on, (Gallien-Krueger MB115ii) had had a purple LED ring around the power button (indicating an under/over voltage or overheating) and no sound.
A tech savvy friend suggested I try putting the PSU board into another identical amp carcass (which had no PSU board at all) to confirm the problem was with the PSU, not the preamp.
The second amp, the ring went red and stayed red.
When I put it back in the original amp, the LED ring no longer turned purple, but stayed red.
I’m having a terrible, unsatisfying experience trying to solder these teeny SMD resistors on. (I’ve never had the pleasure)
Looking at frobek’s photo, it looks like the solder is bridging the pads between the 62K & 5k resistors. TBH, I can’t see any other way to solder them on without the worlds smallest soldering tip…
I wouldn't mess with any SMD resistors just yet! They are a pain, and in the unlikely scenario that one has gone bad, you'll probably need another tool which I'll get to in a second.
It turns out I had an IcePower 125ASX2 not a 50ASX2, but for me it was a transistor that went bad (and it was hidden under a heatsink that I didn't realise was a heatsink). On TR361, check all pairwise connections of pins 1, 2, 3. There should be no continuity or at least very high resistance. Pin 2 connects to the big ground pin. Repeat with the transistor next to it, and then with TR301 and the one next to that.
If any are reading a short circuit, that's your issue. I was very lucky to find a donor 125ASX2 board that was missing a few bits on eBay for quite cheap, so I swapped out the faulty transistor. Now the swapping itself is another story...
You'll have to ask yourself whether you want to up your soldering game! Because those things will not come off with an iron. You'll almost certainly need a hot air rework station. I got a KaiserTech Quick Rework Station for under £100 in the UK. I had to practice removing those transistors on the donor board and I did ruin one with too much heat applied for too long. Mr SolderFix has great videos on how to use them skillfully.
