1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
2. Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
3.
4. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
5. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
6. chi0001: bIII adapters pcb x4, tps7a4700 x4
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator
9. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5, 1 x Dual XO Clock board V3.3
11. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
12. luisbock
13. lxiaob
15 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
16. iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
17. audiopassion
18.ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
19: LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
20. errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
21. sernikus I2S FIFO + Dual XO
22. TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
23. korben69 : 3 x Bare PCB of TPS7A4700, 3 x SMT U.FL socket
24. Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
25. pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
26. JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
Like this
........26.1) PCM1704/63 =my usb interface xmos > i2s FIFO v3.80 assy board + Reclock assy board > my PCM1704s
........26.2) TDA1541=my usb interface xmos >i2s FIFO v xxxxassy board + Reclock assy board > my TDA1541s
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
27. crobbins5421: Dual XO Clock Board, Universal SMT XO Adapters lot of 5
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
28. Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
29. LuisMCP: 4 x BIII Adapter PCB.
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
Current Group Buy Description
So I don't have to search through pages of postings, can someone please tell me the post # that describes the current group buy, and the procedure for how to place on the list, for what items?
Thanks,
Gary
Thanks,
Gary
Not quite korben69 ...
That is the GBIV info. The list here is now GBV expression of interest/waiting list that Ian can use to work out qty of things to order and know when there is sufficient interest to place orders at his convenience. Do not fill out the GBIV spreadsheet, there will be a new one for the next GB.
If you're looking for links to info on what's going on then the wiki (see my sig) and the post that korben69 linked to have all of the info 🙂
Thanks for the update guys! I bought an earlier version FIFO re-clock project and very happy with it. Now looking for one to work with my Buffalo SE III project, so I'll read carefully as to what I might need and add my name to the list.
Cheers!
Cheers!
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
30. TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
31. clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
10. casshan : 4 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 4 x Finished FIFO isolator board v2.5, 4 x Dual XO Clock board V3.3
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
32. Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
33. 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
10. casshan : 4 x I2S FIFO KIT v3.8, 4 x Finished FIFO isolator board v2.5, 3 x Dual XO Clock board V3.3, 1 x Si570 Clock Board V3.5(with Si570), 1 x Finished TPS7A4700 low noise regulator board V2.5
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
34. canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
33. jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
me too
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
35. sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
