Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Thanks Ian for this offer -
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 2x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x battery management boards, 4x Isolator board kit
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 1x I2S backdoor KIT, 1x Package of Universal SMT XO Adapters, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x battery management board, 1x isolator board, 1x Si570 clock board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 3 x battery management board
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 2x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 1 x battery management board
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT for S/PDIF board, 1x Isolator board kit, 1x battery management kit
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x Universal SMT XO
Adapters KIT, 8 x 4" coax cables, 1X Isolator board kit, 2X battery management boards
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT, 4 X battery management boards
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables, 1 x isolator board kit, 2 x battery management board
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO, 5 x isolator board kit
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm;4 x isolator board kit and 4 x battery management board.
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N39 NicMac 20 x battery management boards
N40 leejh 1*I2S FIFO KIT, 1*Dual XO Clock board , 1 x BIII adapter, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x SMT U.FL Socket, 2 x 4" coaxial cable 50ohm, 1 x 6" coaxial cable 50ohm, 1x isolator board kit and 3 x battery management board
N41 necplusultra 1*I2S FIFO KIT,2 x battery management boards
N42 ruupie 1*I2S FIFO KIT, 1*Dual XO Clock board , 2x isolator board kit and 3 x battery management board
N43 crazikid 1x I2S FIFO Kit, 1x Dual XO Clock Board
N44 Odysseas 1xI2S FIFO KIT,2xDual XO Clock board, 1xS/PDIF Interface Board, 2xU.FL coaxial cable connection accessories, 1xI2S backdoor KIT for S/PDIF board, 1xPackage of Universal SMT XO Adapters, 1xAdditional BIII adapters PCB, 1xSMT connector package for BIII adapters, 4xTI boards(if possible), 4xbattery management boards(if possible),1xisolator board
N45 Slartibartfasst 2x battery management board, 2x isolator board
N46 Greg Stewart 1 x isolator board mini kit
N47 DUC985 1xI2S FIFO KIT,1xDual XO Clock board
N48 crobbins5421 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x isolator board kit
N49 MisterRogers 1x I2S FIFO Kit, 2x Dual XO Clock Board, 2x isolator board kit, 2x BIII adaptors 12x 6" U.FL
N50 lwif 1 x isolator board kit, 2 x battery management board ( or more if available)
N51 atom6422 1 x isolator board kit, 2 x battery management board
N52 JamesHill1 x isolator board kit, 1 x battery management board
N53 deanoUK 1x I2S FIFO Kit, 1x Dual XO Clock Board, 26 X SMT U.FL socket, 1 X Package of Universal SMT XO Adapters, 10 x 4” coaxial, 2 x 6” coaxial, 1 x 12” coaxial, 4 X Additional BIII adapters PCB, 5 X SMT connector package for BIII adapters,1 x isolator Board
N54 mravinsky 1x isolator board kit, 5 x battery management board, 8 x 4” double-ended 50 ohm coaxial cable, 4 x 6” double-ended 50 ohm coaxial cable, 10 x SMT U.FL Socket
N55 Popolvar 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 2 x battery management boards,1 x isolator board
N56 qusp 4 x 4” double-ended 50 ohm coaxial cable $2 USD/ea, 1 x backdoor kit, 1 x isolator kit
N57 nvduybom 1x I2S FIFO KIT V3.80 $149- USD/ea, 1x Dual XO Clock board V3.3 $59- USD/ea, 1x S/PDIF Interface Board $89- USD/ea, 1x Additional BIII adapters PCB $3.99 USD/ea, 1x MT connector package for BIII adapters $3.99 USD/ea, 1x Battery management PCB free
N58 TUBO 1 X I2S FIFO KIT V3.80, 1X DUAL XO CLOCK BOARD, 1X SPDIF INTERFACE BOARD, 1X SMT XO ADAPTER PACKAGE, 6X 6" U.FL CABLE, 1X BATTERY BOARD.
N59 Malvin 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x S/PDIF Interface Board, 6x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable, 1x I2S backdoor KIT for S/PDIF board, 1x Package of Universal SMT XO Adapters lot of 5, 1x FIFO isolator board V1.5 MINI KIT, 1x Battery management PCB free
N60 1x TNT I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x S/PDIF Interface Board, 4x 6” double-ended 50 ohm coaxial cable, 1x I2S backdoor KIT for S/PDIF board, 1x Package of Universal SMT XO Adapters lot of 5, 1x FIFO isolator board V1.5 MINI KIT, 1x Battery management PCB free
N61 sernikus 1x FIFO isolator board V1.5 MINI KIT,1x battery management pcb...
N62 markus22ch 1x I2S FIFO KIT, 1x S/PDIF Interface Board, 2x isolator board kit, 1x Dual XO Clock Board
N63 ryanj 2x isolator board kit and 2 x battery management board
No 64 jameshillj Fifo kit (#11); Dual Xo clock (#12); S/Pdif Interface (#13); Socket (#14); cable (#15); cable (#16); Backdoor kit (#18); plus daughter brd for NOS, and battery board. (I'm the James Hill from Australia, not England!)
No 65 Nikola Krivorov - SMT U.FL socket, 4"double-ended U.FL coaxial cable, 6"double-ended U.FL coaxial cable, 12"double-ended U.FL coaxial cable, I2S backdoor KIT for S/PDIF board ,2x FIFO isolator board V1.5 MINI KIT,2 x battery management board, 10P 1.0mm FFC/FPC cables combo (3 cables)
No. 66 Regal Package of Universal SMT XO Adapters lot of 5 ,additional BIII adapters PCB $3.99 USD/ea, SMT connector package for BIII adapters $3.99 FIFO isolator board V1.5 MINI KIT,1.0mm FFC/FPC cables combo $3.99 USD
N67 spm 2x backdoor, 4 x isolator. Thx
Ian FIFO KIT GBIII is closed
Order form received so far Dec09
09,11,12,17,18,19,20,21,22,24,25,26,27,28,29,30,32,35,36 ,37 ,38,40,41,42,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66.
#67 is under waiting.
I'll send the paypal invoice very soon. Hopefully I can finish GBIII shipment in this week.
You can open a new waiting list if more people interested in. Si570 clock board, finished isolator board and finished TPA7A4700 PCB will be included in GBIV.
Thanks,
Ian
Invoice sent to your PayPal email on Dec10 :
09,11,12,17,18,19,20,21,22,24,25,26,27,28,29,30,31,32 ,35,36 ,37, 38,40,41,42,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67.
Please let me know if you didn’t receive the invoice.
Ian
Ian,
I have not received any info from paypal, but since you posted here info I went myself to my paypal account and found your invoice. It seems like something with my paypal account, but anyway, I have sent you payment.
AR2
SI570XXX version
Hi Ian, since GB IV is so near ;-)
Reading the post on the SC-crystal oven from Andrea made me check the specifications of my SI570 boards I purchased 1-2 years ago. I have a SI570BBC and a SI570CAC what version have you tested and what version will you put in the futur SI570 board in GB IV?
I saw in the datasheet that a 7ppm Temperature Stability (20ppm total) version SI570?C? should exist. The Si570 BBC000141DG LVDS (280 MHz Max) seems the affordable one vs specs ...
I think you're being a touch optimistic on how near GBIV is 😉 Have a read about when GBIII opened and it is just finishing up now after taking a few months to reach numbers required. Ian isn't doing this full time at these prices it is just not possible to do continuous production of these kits.
Discussion of Si570 versions would be a good question to ask in the R&D thread 😉
Ian I've sent you an email, I didn't receive an invoice.
Chris
Chris
Seems paypal don't send email notification right away. A invoice was in my paypal account so I paid It... Ian payment for no 12 done!
I will transfert posting in the SI570 R&D thread...
Ian,
AR2
Yes, all invoices sent to Paypal email address. But I've noticed that some times Paypal didn't send them on time.Please check your Paypal account if it is possible. Any way, I'll send them again this evening after work.
Ian
