Order form received so far Nov29
09,11,12,17,18,19,20,21,25,26,27,28,29,30,32,35,36 ,37 ,38,40,42,44,45,46,47,48,49,50,52,53,54,55,56,57,58.
Please let me know if I didn't get your order form.
Thanks,
Ian
Thanks,
Ian
Hopefully everything will get ready for delivery by the end of next week. Will send Paypal invoice then.
Have a nice weekend.
Ian
Ian
Ian,
I would like to add the isolation board on my order.
Pls advice on how to proceed..
thanks again
thanks again
Ian,
thanks again
No problem, I'll do it for you.
Ian
Hope it's not too late, added myself to the list:
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 2x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x battery management boards, 4x Isolator board kit
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 1x I2S backdoor KIT, 1x Package of Universal SMT XO Adapters, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x battery management board, 1x isolator board, 1x Si570 clock board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 3 x battery management board
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 2x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 1 x battery management board
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT for S/PDIF board, 1x Isolator board kit, 1x battery management kit
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x Universal SMT XO
Adapters KIT, 8 x 4" coax cables, 1X Isolator board kit, 2X battery management boards
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT, 4 X battery management boards
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables, 1 x isolator board kit, 2 x battery management board
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO, 5 x isolator board kit
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm;4 x isolator board kit and 4 x battery management board.
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N39 NicMac 20 x battery management boards
N40 leejh 1*I2S FIFO KIT, 1*Dual XO Clock board , 1 x BIII adapter, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x SMT U.FL Socket, 2 x 4" coaxial cable 50ohm, 1 x 6" coaxial cable 50ohm, 1x isolator board kit and 3 x battery management board
N41 necplusultra 1*I2S FIFO KIT,2 x battery management boards
N42 ruupie 1*I2S FIFO KIT, 1*Dual XO Clock board , 2x isolator board kit and 3 x battery management board
N43 crazikid 1x I2S FIFO Kit, 1x Dual XO Clock Board
N44 Odysseas 1xI2S FIFO KIT,2xDual XO Clock board, 1xS/PDIF Interface Board, 2xU.FL coaxial cable connection accessories, 1xI2S backdoor KIT for S/PDIF board, 1xPackage of Universal SMT XO Adapters, 1xAdditional BIII adapters PCB, 1xSMT connector package for BIII adapters, 4xTI boards(if possible), 4xbattery management boards(if possible),1xisolator board
N45 Slartibartfasst 2x battery management board, 2x isolator board
N46 Greg Stewart 1 x isolator board mini kit
N47 DUC985 1xI2S FIFO KIT,1xDual XO Clock board
N48 crobbins5421 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x isolator board kit
N49 MisterRogers 1x I2S FIFO Kit, 2x Dual XO Clock Board, 2x isolator board kit, 2x BIII adaptors 12x 6" U.FL
N50 lwif 1 x isolator board kit, 2 x battery management board ( or more if available)
N51 atom6422 1 x isolator board kit, 2 x battery management board
N52 JamesHill1 x isolator board kit, 1 x battery management board
N53 deanoUK 1x I2S FIFO Kit, 1x Dual XO Clock Board, 26 X SMT U.FL socket, 1 X Package of Universal SMT XO Adapters, 10 x 4” coaxial, 2 x 6” coaxial, 1 x 12” coaxial, 4 X Additional BIII adapters PCB, 5 X SMT connector package for BIII adapters,1 x isolator Board
N54 mravinsky 1x isolator board kit, 5 x battery management board, 8 x 4” double-ended 50 ohm coaxial cable, 4 x 6” double-ended 50 ohm coaxial cable, 10 x SMT U.FL Socket
N55 Popolvar 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 2 x battery management boards,1 x isolator board
N56 qusp 4 x 4” double-ended 50 ohm coaxial cable $2 USD/ea, 1 x backdoor kit, 1 x isolator kit
N57 nvduybom 1x I2S FIFO KIT V3.80 $149- USD/ea, 1x Dual XO Clock board V3.3 $59- USD/ea, 1x S/PDIF Interface Board $89- USD/ea, 1x Additional BIII adapters PCB $3.99 USD/ea, 1x MT connector package for BIII adapters $3.99 USD/ea, 1x Battery management PCB free
N58 TUBO 1 X I2S FIFO KIT V3.80, 1X DUAL XO CLOCK BOARD, 1X SPDIF INTERFACE BOARD, 1X SMT XO ADAPTER PACKAGE, 6X 6" U.FL CABLE, 1X BATTERY BOARD.
N59 Malvin 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x S/PDIF Interface Board, 6x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable, 1x I2S backdoor KIT for S/PDIF board, 1x Package of Universal SMT XO Adapters lot of 5, 1x FIFO isolator board V1.5 MINI KIT, 1x Battery management PCB free
The backdoor kit is described in the spdif manuals. It gives an optional i2s input on the spdif board.
Tnxs!The backdoor kit is described in the spdif manuals. It gives an optional i2s input on the spdif board.
Hallo!
I'll bite...
N60 1x TNT I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x S/PDIF Interface Board, 4x 6” double-ended 50 ohm coaxial cable, 1x I2S backdoor KIT for S/PDIF board, 1x Package of Universal SMT XO Adapters lot of 5, 1x FIFO isolator board V1.5 MINI KIT, 1x Battery management PCB free
I'll bite...
Tnxs!
Hi TNT,
I see you are on the list now. Could you please download the order form and send it back to me ?
Ian
N61 sernikus 1x FIFO isolator board V1.5 MINI KIT,1x battery management pcb...
Order form received so far Dec03
09,11,12,17,18,19,20,21,25,26,27,28,29,30,32,35,36 ,37 ,38,40,41,42,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61.
Thanks,
Ian
Thanks,
Ian
GBIII will be closed on this weekend
I'm almost ready. GBIII will be closed on this weekend. I'll send PayPal invoice at that time. Just hope I can get them shipped within next week.
Ian
Ian
Hi Ian
One more on the list. Just finished yesterday my prototyp dac with the FIFO....
Orderform is on the way.
N62 markus22ch 1x I2S FIFO KIT, 1x S/PDIF Interface Board, 2x isolator board kit, 1x Dual XO Clock Board
Ian
Ian, do You have my N60 order email?
Yes TNT, thank you for your order 🙂.
Ian
Order form received so far Dec05
09,11,12,17,18,19,20,21,22,24,25,26,27,28,29,30,32,35,36 ,37 ,38,40,41,42,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62.
Thanks,
Ian
Thanks,
Ian
Hi Ian, I added myself to the list for a couple of things. If there is none left ill wait for next time. Thanks for providing such great products for all of us.
N63 ryanj 2x isolator board kit and 2 x battery management board
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
