bercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1xI2S FIFO KIT v3.80, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter
nanocamp: pcm
lordvader : 1x I2S to PCM converter
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board,5 x pkg Universal SMT XO Adapters,2x I2S to PCM converter
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material , x8 I2S to PCM converter , x2 spdif interface
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
curryking: 12 x Dual XO clock board
bisesik: 1x I2S to PCM converter
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
SomekPoland: 1x I2S to PCM
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
vertigen: 1xPackage of Universal SMT XO Adapters
zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit
lbamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
nautibuoy: 1 * Finished I2S FIFO Board; 1 * Finished Si570 Clock board (with Si570); 1* Finished Isolator Board (with i2c isolation?); 1* Finished TPS7A4700 regulator; 4 * 4in U.FL cables; 1 * Finished Battery Management Board
zapio : 3x Dual Clock board
Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
name_hase: 1* I2S to PCM converter
SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable
sebna: 4x Finished TPS7A4700 regulator
Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters
Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board
skybug: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x Finished FIFO Isolator Board, 2x Finished TPS7A4700 low noise regulator board
emyeuoi: 1X I2S FIFO Kit, 1X Dual XO Clock Board, 1X Finished FIFO Isolator Board, 2X SMT U.FL Socket, 6X 4" double-end siver plated U.FL coaxial cable, 6X 6" double-end siver plated U.FL coaxial cable
Nikon1975: 2x I2S to PCM converters
ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket
COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board
mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC
kazap: 1x Finished TPS7A4700 low noise regulator board ,4x 6"double-ended U.FL coaxial cable, 4x SMT U.FL socket,
Luke: 1* Finished I2S to PCM Board; 12* SMT U.FL socket; 10* 4" U.FL doublr ended coax cable
sernikus : 2x DualXoBoard
Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
zlahmoon : 2 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
walangalam: 1x I2S to PCM converter
lintweaker: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GaryB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator V2.5, 1 x S/PDIF Interface Board
ryanj: 1x I2S to PCM converter, 1X Finished FIFO Isolator Board, 4x Finished Battery management board
JimS:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator
Eldam: 2x I2S to PCM converter, 16 x 4" double-ended U.FL coaxial cables (if 2" : should be appreciated).
badrisuper: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
damohpi: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock Board, 1x I2S - PCM Converter Board
LuisMCP: 3 x (Dual XO + i2s FIFO + Finished FIFO Isolator) + 2 x (I2S to PCM Converter + 1 x (Finished Battery Mngmnt brd. + SPDIF interface brd.)
IanS1 : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
bkdog: 1 x Dual XO board
mjensen: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,2x Finished FIFO Isolator
dubai2000: 1x I2S FIFO KIT, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5
Aronier: 2x I2S FIFO Kit, 2x Finished FIFO Isolator, 2x Si570 Clock Board V3.5(with Si570), 2x low noise reg 2x I2S - PCM Converter Board, 2x 4 x 4" double-ended U.FL Coax, 2x Finished Battery management board
Aive: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board, 1 x SPDIF Interface Board, 1 x Finished FIFO Isolator, 2 x finished adapters for Crystek, 2 x 8" double-ended PH 2.0mm 7-pin I2S cables, 6 x 6" double-ended U.FL coaxial cable
brookbphx: 3x SMT XO adapter[/QUOTE
Myint67: 1x finish SPDIF interface board ,6 x 4" double ended Ufl,12inch double end 50ohm coaxial cable,L2S PCM board.
nedi: 1x finished Battery Management kit
danielkol: 2 x I2S to PCM converter board V2.0;
nacder: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 2x SPDIF Interface Board, 2x Finished FIFO Isolator Board, 2x Adapters for Crystek, 6x SMT u.fl sockets, 6x 6" Double-ended u.fl Coaxial Cables.
chi0001: 10x SMT XO adapter, 5x U.FL input adapter, 2x finished FIFO-Clock Isolation, Board, 1 x Finished Si570 Clock board (with Si570), 1 x I2S to PCM converter
kenlaumm: 1x I2S FIFO KIT, 1x Finished FIFO Isolator Board
lazybonesxp: 1 x I2S to PCM converter, 8 x U.FL socket, 8 x 4" double-ended U.FL Coax
emrpus: 1x I2S FIFO Kit, 1x Finished FIFO Isolator, 1x Dual XO Clock
ceglar: 1x Dual XO v2.0
tubesguy: 1x Dual XO II
giordano: 1x I2S FIFO Kit, 1x Dual XO Clock (II?)
MarcellD: 1x Si570 Clock Board V3.5(with 10MHz Si570), 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT
Fridrik: 1x I2s to PCM, 4 x 4" Double-ended u.fl Coaxial Cables,8 x U.FL socket,.
Clsidxxl:1x Dual XO II
kvl: 2x I2S FIFO Kit, 2x Dual XO Clock Board II, 1x SPDIF Interface Board, 1x Finished FIFO Isolator Board
Arledgsc: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, FIFO Isolator board V 2.5, U.FL Connectors/ Cables
davej:1x Dual XO II
rab28: 1x I2S FIFO Kit, 1x Dual XO Clock Board II, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x I2S - PCM Converter Board
TNT: 2x Dual XO II
hirez69: 2x DualXO II
heathkit: 1x I2S FIFO kit, 1x Dual XO Clock Board II
grepap: 1x I2S to PCM converter
ppap64: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1 x I2S to PCM Converter
Zoran: 2x DualXO II
Nikon1975: 1x I2S FIFO kit, 1x Dual XO Clock Board II
MeiT: 1 x I2S FIFO Kit, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
andrea_mori: 3 x Dual XO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Crom: 1x Dual XO v2.0
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
tods: 1 x I2S FIFO Kit v.3.80, 1 x Dual XO Clock Board II, 1 x S/PDIF Interface Board, 4 x SMT U.FL socket, 4 x 4"double-ended U.FL coaxial cable,
4 x 6"double-ended U.FL coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 1 x Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, 2 x Bare PCB of TPS7A4700 low noise regulator, 1 x I2S to PCM Converter
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Stixx: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, , 1 x I2S to PCM Converter
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
ripson: 1 x I2S FIFO finished, 1 x Dual XO Clock board, 1 x finished FIFO isolator, 1 x S/PDIF Interface Board
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Zoef: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board, 1 x Finished FIFO Isolator Board v.2.5
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
palmito: 1 x Dual XO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
tagheuer: 1 x Dual XO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Hi Ian,
I may have missed something of the long going post.
What's the other improvement of Dual XO II over the previous one?
By any chance if it could provide a /2 and /4 divider so I can feed the clock to other device like BBB or Amanero module?
Thanks Ian
Thanks Ian
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Added 1 item more
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Lindamar: 16x SMT U.FL socket, 3x Additional BIII adapters, 3x SMT connector package for BIII adatpers, 4x 10P 1.0mm FFC/FPC cables combo (3 cables), 4x 4" double-ended silver plated U.FL coaxial cable, 2x Dual XO II
jimchan : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator[/QUOTE]
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Also updated my request.
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Zoef: 1 x Finished I2S FIFO Kit (v 3.80?), 1 x Finished Dual XO Clock Board (II?), 1 x Finished FIFO Isolator Board v.2.5
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
1 more
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
Luanak:1x Dual XO Clock, 1x I2S to PCM Converter
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
added myself to the list
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
minionas: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
vanwykca: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, Package of Universal SMT XO Adapters, 1x I2S to PCM Converter, 1x Finished TPS7A4700 low noise regulator board V2.5.
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
RollE2k: 1 x I2S FIFO Kit v 3.80, 1 x Dual XO Clock Board II, 1 x Finished FIFO Isolator Board v.2.5, 1x Package of Universal SMT XO Adapters, 1x S/PDIF Interface board, 1x I2S backdoor KIT for S/PDIF board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x 10P 1.0mm FFC/FPC cables combo.
By the way, i have totally lost myself in this thread - is this waiting list for everything - and when there is a new GB, we just fill out the order form and email it to ian?
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
sidiropa: 2x Dual XO Clock Board II
nanocamp: pcm
Gogi x1 PCM board
davej:1x Dual XO II
TNT: 2x Dual XO II
Zoran: 2x DualXO II
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
