I get a kit but it appear i change my plan for the dac i want to build. If someone is interested i have this kit for sell, i will of course sell it the price i paid and it's completly new. I will sell the complete kit. I have :
I2S FIFO kit + 4"double-ended U.FL coaxial cable + Si570 Clock Board V3.5 with clock + Finished FIFO isolator board V2.5 + Finished TPS7A4700 low noise regulator board V2.5 + I2S to PCM converter board V2.0 + 4" double-ended silver plated U.FL coaxial cable
I also have a finished Twisted Pear Audio Otto digital switch than can fit the kit, if someone is interested you can send me a PM.
jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x SMT XO Adapters KIT, 1x Finished FIFO Isolator Board, 3x SMT finished Battery Management KIT, 2x I2S to PCM converter, ##x U.FL Cables
nanocamp: pcm
lordvader : 1x I2S to PCM converter
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board.
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material , x8 I2S to PCM converter , x2 spdif interface
clsidxxl:1x finished Battery Management kit
kokonut : 1x I2S to PCM converter
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
curryking: 10 x Dual XO clock board,5 x 6" double-ended U.FL coaxial cable,6 x package of universal SMT XO adapter kit
bisesik: 1x I2S to PCM converter
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
SomekPoland: 1x I2S to PCM
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
vertigen: 1xPackage of Universal SMT XO Adapters
zjerneic: 1x S/PDIF Interface Board; 1xI2S FIFO kit
tame:1xI2S to PCM board
lbamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
nautibuoy: 1 * Finished I2S FIFO Board; 1 * Finished Si570 Clock board (with Si570); 1* Finished Isolator Board (with i2c isolation?); 1* Finished TPS7A4700 regulator; 4 * 4in U.FL cables; 1 * Finished Battery Management Board
zapio : 3x Dual Clock board
Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
name_hase: 1* I2S to PCM converter
SalvationMen: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x Package of Universal SMT XO Adapters, 2x Additional BIII adapters PCB, 2x SMT U.FL socket, 8x 4” double-ended 50 ohm coaxial cable
sebna: 4x Finished TPS7A4700 regulator
Nige2000: 2x I2S FIFO KIT, 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 6x Package of Universal SMT XO Adapters, 2x Si570 Clock Board, 2x I2S to PCM converters
Jogi: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board
skybug: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x Finished FIFO Isolator Board, 2x Finished TPS7A4700 low noise regulator board
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
emyeuoi: 1X I2S FIFO Kit, 1X Dual XO Clock Board, 1X Finished FIFO Isolator Board, 2X SMT U.FL Socket, 6X 4" double-end siver plated U.FL coaxial cable, 6X 6" double-end siver plated U.FL coaxial cable
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
Nikon1975: 2x I2S to PCM converters
nanocamp: pcm
Gogi x1 PCM board
mhgawel: 1x I2S to PCM converter
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
Hi
For those looking at Ian's TPS7A4700 regs :
http://www.diyaudio.com/forums/swap-meet/254822-fs-tps7a4700-regs-iancanada-design.html
Phil
Phil
nanocamp: pcm
Gogi x1 PCM board
tubesguy: 1X I2S FIFO Kit, 1X Dual XO Clock Board, 1X Finished FIFO Isolator Board, 1x I2S to PCM convertor board
nanocamp: pcm
Gogi x1 PCM board
Hi all,
if anyone was interested in the custom Laptech crystal
http://www.diyaudio.com/forums/grou...hronous-i2s-s-pdif-fifo-kit-group-buy-70.html
please add your name in the wish list at
http://www.diyaudio.com/forums/digital-line-level/203511-any-good-tda1541a-dac-kit-96.html
The minimum orderable quantity from Laptech is 5 pcs for each frequency.
When that quantity will be reached I ask Laptech for a quote.
Andrea
Andrea
nanocamp: pcm
Gogi x1 PCM board
ernesternest: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board, 1x I2S to PCM converter, 4x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
COX77 : 1x I2S FIFO KIT V3.80, 1xS/PDIF interface board,
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
mikeg88: (1x) I2S FIFO KIT V3.80, (1x) Dual XO Clock Board, (1x) Finished FIFO Isolator Board, (1x) Package of Universal SMT XO Adapters, (6x) 6" double-ended U.FL coaxial cables, (1x) 2" double-ended PH 2.0 mm 7-pin I2S bridge cable, (1x) 2" 10-pin FPC/FFC cable, (1x) universal i2s isolator PCB, (1x) U.FL signal input connector board for BIII DAC
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
kazap: 2x I2S FIFO KIT V3.80 , 2x Dual XO Clock Board, 2x Finished FIFO Isolator Board, 1x I2S to PCM converter, 2x SMT Finished Battery management mini kit, 2x Finished TPS7A4700 low noise regulator board ,8x 6"double-ended U.FL coaxial cable, 8x SMT U.FL socket, 1 x spdif interface, 1* I2S backdoor kit for S/PDIF boar.
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
1* Finished I2S FIFO Board; 8* SMT U.FL socket; 8* 4" U.FL doublr ended coax cable; 1* Finished TPS7A4700 low noise regulator board V.2.5
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
Luke: 1* Finished I2S FIFO Board; 8* SMT U.FL socket; 8* 4" U.FL doublr ended coax cable; 1* Finished TPS7A4700 low noise regulator board V.2.5
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
sernikus : 2x DualXoBoard
nanocamp: pcm
Gogi x1 PCM board
Brumjam : 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x finished FIFO isolatorbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
