GBVFIFO66 received over the weekend!
Super efficient dispatch & delivery and I'm thoroughly looking forward to piecing it all together.
Thank you Ian!
Thank you Ian!
GBVFIFO01 : jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
GBVFIFO02 : Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
GBVFIFO03 : APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
GBVFIFO04 : duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
GBVFIFO05 : chi0001: bIII adapters pcb x4, tps7a4700 x4
GBVFIFO06 : hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
GBVFIFO07 : malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
GBVFIFO08 : mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
GBVFIFO09 : casshan : 1 x I2S FIFO KIT v3.8,2 x Finished FIFO isolator board v2.5,2 x Si570 Clock Board V3.5 (with Si570),2 x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO10 : hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO11 : luisbock
GBVFIFO12 : kazap: 1x i2s FIFO kitv3.80, 1x Dual XO Clock Board, 1x finished isolator, 1x TPS7A4700, 1x Battery management, 1 x S/PDIF , 1 x I2S backdoor KIT, 4x 6” 50 coaxial cable, 1x XO Adapters, 10x SMT U.FL socket
GBVFIFO13 : iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
GBVFIFO14 : audiopassion
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
GBVFIFO16 : LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO17 : errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
GBVFIFO18 : sernikus I2S FIFO + Dual XO
GBVFIFO19 : TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
GBVFIFO20 : korben69 : 4 x Bare PCB of TPS7A4700
GBVFIFO21 : Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
GBVFIFO22 : pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
GBVFIFO23 : JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
GBVFIFO24 : crobbins5421: 1 x Finished FIFO board, 1 x Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO25 : Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
GBVFIFO26 : LuisMCP: 4 x BIII Adapter PCB.
GBVFIFO27 : TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
GBVFIFO28 : clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5,3 x 6" coax cable and 3 x SMT U.FL socket
GBVFIFO29 : Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
GBVFIFO30 : jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
GBVFIFO31 : canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
GBVFIFO32 : sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO33 : hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
GBVFIFO34 : zapio : 1 x Si570 , 2 x finished FIFO isolator
GBVFIFO35 : fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
GBVFIFO36 : fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
GBVFIFO37 : nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
GBVFIFO38 : manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
GBVFIFO39 : Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GBVFIFO40 : Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO41 : Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
GBVFIFO42 : curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
GBVFIFO43 : vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
GBVFIFO44 : Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
GBVFIFO45 : wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
GBVFIFO46 : _oxygen: 1x FIFO Kit, 1x Si570 Clock Board (with Si570), 2x Finished FIFO isolator board, 1x SPDIF Interface Board, 1x i2s Backdoor Kit, 3x Finished TPS7A4700 low noise regulator board, 1x SMT finished Battery Management Mini Kit, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO47 : frd__: 10x Bare PCB of TPS7A4700 low noise regulator
GBVFIFO48 : palmito: 1 FIFO board, 10 PCB of TPS7A4700 low noise regulator
GBVFIFO49 : brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
GBVFIFO50 : davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
GBVFIFO51 : flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBVFIFO52 : Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
GBVFIFO53 : Popolvar: 1 x FIFO board, 1 x dual XO
GBVFIFO54 : necplusultra: 1 fifo board,1 x Si570 board (with Si570), isolator board, 5 TPS7A4700 boards
GBVFIFO55 : crowlie: 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 4x Passive Battery Management Board V2.5 Mini KIT, 10x SMT U.FL socket, 8x 4" double-ended 50 ohm coaxial cable, 6x 6" double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO56:curryking: 4 x Dual XO Clock Board,4 x 6" double-ended U.FL cable,2 X Package of universal SMT XO Adapters Kit
GBVFIFO57 : Alcaudon: 1 x Dual XO Clock Board, 5 x BIII Adapters PCB, 3 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable.
GBVFIFO58 : ruupie: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 2 x BIII Adapters PCB, 2 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable
GBVFIFO59 : tofurky : 1x finished TPS7A4700 regulator, 2x TPS7A4700 bare pcb
GBVFIFO60 : MarcellD : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1x I2S to PCM converter board
GBVFIFO61 : Marek : 1x Dual XO Clock Board (if available), 1x Finished FIFO isolator board V2.5, 1x Package of Universal SMT XO Adapters KIT lot of 5, 21x SMT U.FL socket, 9x 4"double-ended U.FL coaxial cable
GBVFIFO62 : 4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
GBVFIFO63 : normundss : 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO64 : Greg Stewart : 1 x i2s FIFO kit
GBVFIFO65 : znarfomat : 1x I2S FIFO KIT, 1x Dual XO Clock board
GBVFIFO66 : Crom : 1x I2S FIFO KIT, 1x Dual XO Clock board, 1 x complete isolator board v2.5, 2 x BIII adapter kit
GBVFIFO67 : gugi100 :4x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO68: curryking : 2 x 6"double-ended U.FL coaxial cable,1 x Additional BIII adapter PCB,1 x SMT connector package for BIII adapter,2 x Si570 Clock Board V.3.5 with Si570,2 x Finished TPS7A4700 Low noise regulator board.
GBVFIFO69: GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters, 1x PCM1704 board when ready
GBVFIFO70: TV Man: 1 FIFO Board, 1 Finished TPS7A400 regulator board, 1 Si570 Clock board, 1 FIFO Isolator board, misc. uFL cables
GBVFIFO71: TNT: 1 FIFO Board, 2 Finished TPS7A400 regulator board, 1 complete Si570 Clock board, 1 FIFO Isolator board, misc. uFL cables, 1 x spdif interface
GBVFIFO72: Malvin: 1x Finished FIFO Isolator board v2.5
GBVFIFO73: Ben Mah: 1xFIFO Board, 1xIsolator Board v2.5, 1xDual XO clock board, 1xUniversal SMT XO adapters kit, 2xTPS7A4700 regulator board, UFL sockets and cables
GBVFIFO74: Flyingsparks: 1xFIFO Board, 1xIsolator Board v2.5, 1xSi570 Clock Board (with Si570), 2xTPS7A4700, 2xBattery Management v2.5 Kit, 1xFFC/FPC Cables, 1x SMT Kit for BIII adaptors, 10x U.FL sockets
Hi Ian.
Is it too late to jump on the GBVPCM bandwagon ?
Been living under a rock the past few months, and missed it completely !
Hi Ian.
Hi lordvader,
GBV was closed last week 🙂. I'll set up a new waiting list to see if there is chance for next one.
Hi guys, please let me know if you not yet receive the KIT and need my help with post office.
Regards,
Ian
Ian FIFO and PCM board GBVI waiting list
Please add your ID to the waiting list if you are interested in next GB. Or, please remove your ID if I put it with wrong
jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Ian
Ian
roger57: 1x I2S FIFO KIT V3.80
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
