Ian asynchronous I2S and S/PDIF FIFO KIT group buy
I will be ready when you are Ian 🙂
I'd better talk to qusp soon about a combined digikey/mouser order for some XOs and isolator board parts I think.
Though I will ask you not send battery PCB to me, I cannot see me trying batteries for some time and I would prefer the PCBs went to those who are likely to use them in the near term.
Chris
We already got 29 no the list. It seems I have to launch a new production very soon. It will be very fast this time, because I keep all the empty PCBs in stock, as well as some of the BOM.
The only thing I'm afraid is that the Si570 clock board couldn't catch up with this GB, will list it for next time.
Ian
Hi Ian
Will the foot print of the Si570 clock board the same as the dual clock board? As I am putting everything into the case and have to consider this upgrade as well.
Ian,
should I put my name on the list since I am very much interested in isolator board and battery management board? I am interested in new clock board, but I see you are not offering it yet. So I do not want to miss these two items, but do not want to create mess ether with the list, since I already have Fifo board. Please advise.
Thank you
Ian,
Thank you
Hi Ian,
Same here, I also interested in your isolator, battery management and clock board.
I will post new order form together with GBIII details once GBIII is starting, please send back the order form then.
Please don't send me order form now, just make sure you are on the list, because the form will be updated.
I'll supply isolator board mini kit and free battery management board PCB for GBIII, but the factory finished isolator board would come together with Si570 clock board.
Ian
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 2*I2S FIFO KIT, 2*Dual XO Clock board , 2*S/PDIF Interface, 4 x BIII adapter, 2x I2S backdoor KIT for S/PDIF board, 4x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x
Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 8 x 4" coax cables
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
Added to my order.
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
koldby
__________________
Universal SMT XO Adapters KIT, 8 x 4" coax cables
I have removed the S/PDIF interface board from my order.
Roumen
just for clock
just got from Laptech... HC 49 cold welded polished AT crystal
Frequency: 11.2896 MHz
Mode: fundamental
FL: 2.7 ppm
RR: 10 ohm
C0: 2.6 pF
C1: 12 fF
Q: 160 k
not very bad, now it need the right circuit to keep an high loaded Q
The ideal circuit is the two transistor Butler oscillator, with crystal between two emitters, so it see the lower impedance and its high Q is not affected by the load.
It promises a good phase noise performance, now it's the time for experimenting with it.
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 1x isolator board kit , 1 x battery management board
Update for Fridrik added 1x isolator board kit and 1 x battery management board
Mode: fundamental
FL: 2.7 ppm
RR: 10 ohm
C0: 2.6 pF
C1: 12 fF
Q: 160 k
Please let me know your testing result. Good luck.
Ian
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
Update for palmito added 1x isolator board kit and 1 x battery management board
N39 20 x battery management boards
Do I like the battery management board? 😀
