Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Hi Ian
Great update with your prices🙂
Does the FiFoPi comes with crystals or would one have to buy them separately and then use the “A9. Package of dedicated CCHD957 XO adapter kit lot of 2” + a set of 45/49 MHz crystals?
If so, what type of crystal fits your adaptor kit?
Yse, FifoPi comes with pair of 45/49MHz XOs, as same as the McDualXO board. They are good for start up, but not from the top of the line. You can upgrade to CCHD957 through Package of dedicated CCHD957 XO adapter kit lot of 2, or other SMT XOs through Package of XO adapter kit lot of 5.
You will not need any adapter for DIP XOs.
Regards,
Ian
Regards,
Ian
Thank you very much Ian. That sounds really great and there is still room later on for an update if wanted. Great pricing🙂
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController …
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh 2x FifoPi, 1x LiFePO4 power, 2x ESS Controller, 1x dual mono ES9038 DAC, 1x ES9028 DAC, 1x Transformer I/V PCB mini kit, 1x Std I/V stage
6. Randytsuch 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
7. necplusultra 1 x FifoPi, 1xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi + LifeO4 pure power supply + Transformer I/V PCB mini KIT
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 9 x Fifopi, 7 x Ess Controller, 7 x dual mono 9038 dac hat, 6 x I/V STD standard I/V stage, 1 x Transformer I/V PCB, 8 x LifePO4 pure power supply, 1 x McFIFO, 1 x McDualXO
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 3 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 DAC hat, 1 x 9028 DAC hat, 1 x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 8 x 2" u.fl silver-plated extension cables, 5 x RPi metal standoff sets, 5 x LT3042 regulator boards
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat,1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB 1 x ESS Controller
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 2 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB
27. janho12345: 1x FifoPi
28. Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 2X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: Withdrawn (After some consideration decide to withdraw from this GB)
44. _oxygen: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
45. SonofThor: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
46. Morde: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
47. 1001meier: 1xFifoPi, 1x LifePo4 power
48. deenoo: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
49. Robs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
50. linh0983 : 1xLiFePO4 power , 1xDual Mono ES9038Q2M , 1x FifoPi
51. JoeyDD: 1*LifePO4 power, 1*ESS controller
52. pierantonio: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
53. xaled: 2x FifoPi, 2x LifePo4 power, 2x ESS controller, 2x Dual Mono ES9038Q2M, 2*Transformer I/V PCB mini KIT
54. Duanbui: 1xLiFePO4 power
55. maartn: 1x FifoPi, 1 x ESSController, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 2* ADM715X ultra-low noise LDO PCB (free)
56. syracuze: 1 X FifoPi , 3 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
57. Flyingsparks: 2X FifoPi , 2X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
58. number9, 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
59. duc985: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
60. Lucser: 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage and, if completed, 2 x I2S to LVDS HDMI Tx modules as per #2602 post.
61. Stokessd: 1x FIFO, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x Transformer I/V PCB mini KIT
62. tomcoppa 1*FifoPi, 1*LifiPO4 power, 1*EssController, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini KIT
63. Blitz: 3xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
64. Chipno :1 x FifoPi , 1 x LifiPO4 power
65. simon dart: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
66. kolossos4730: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
67. mksung: 1*FifoPi
68. stavros61:1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
69. cjunkk: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
70. bartb: 1x McFIFO, 1x McDualXO, 1x LifiPO4-pure
71.JimS::1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 2 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
72.KenI:1*FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1*ESS controller, 1*Dual Mono ES9038Q2M DAC HAT, 1*I/V STD standard I/V stage
73.kvl: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
74 secanbj 1*FifoPi, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage
75.deanoUK :1 x FifoPi 768KHz 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M
76. cubano: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
77. Hellokitty123: 1X LifiPO4 pure power supply / 1X I/V STD standard I/V stage 1X / Transformer I/V PCB mini KIT
78. nori1000: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, Or 1x Isolator II, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT,
79. Rowli: 2 x LifiPO4
80. Sidiropa: 1*LifePo4 power
81. stephengrenfell 1*FifoPi, 1*LifiPO4 power
82. Mindfunk: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
83. tanelip: 1*FifoPi, 2*LifiPO4 power
84. sbiswas-1: 1 x McFIFO, 1x McDualXO,1x LifiPO4 pure power supply
85. Jjazz: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
86. s666foto: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
87. niner: 2 x LifiPO4
88. maui: 1 * FifoPi, 1 * LifePO4, 1 * I/V STD standard I/V stage, 1 * Transformer I/V PCB mini kit, 8 * U.Fl wire single (or dual) ended coax, 1 * XO adapter kit lot of 5, 1 * ESS Controller, 1 * dual mono 9038 dac hat, Rpi I2S adapter
89. ofswitched: 1 * FifoPi
90. neslo: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
91 AlanElsdon:1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
92 cv: 2 x FifoPI
93. chi0001: 1 x FifoPi, 1 x LifePO4 power, 2 x 2 x Ess Controller, 1 x dual mono 9038 dac hat, 1X I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit
94. cps3113:1 X LifePO4 pure power supply.
95. ilgavro 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
96. ykharlamov: 1 x LifePO4 power, 1 x McFIFO, 1 x McDualXO
97. M_Balou: 1*FifoPi
98. yaboin: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini kit
99. stenachio: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage
100. ilraffa 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
101. ermine22. 2X FifoPi , 1X LifiPO4 power , 2X ESS controller, 2X Dual Mono ES9038Q2M, 2X I/V STD standard I/V stage
102. cesare2K. 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
103. artmic: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*transformer I/V PCB mini kit
104. lugo689:1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 dac hat 1 x std standard I/V stage
105. tods:2x fifopi, 1x lifepo4 power, 1 x esscontroller, 1 x dual mono 9038 dac hat, 1 x std standard I/V stage
106. copper31: 1 x FifoPi, 1 x LifePO4 power
107. plsm: 1*FifoPi, 1*ESS Controller, 1*dual mono 9038 dac hat
108. Gabry63: 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
109. dynpro100: 1 x I2S to PCM converter board, 1 x Finished TPS7A4700 low noise regulator board, 1 x RaspberryPi I2S adapter PCB/connector package
110. sp502: 1 x McFIFO, 1 x McDualXO, 1 x Finished TPS7A4700, 9x U.FL. coax cable (4",7",12"), 10x U.FL. sockets, 1x SMT XO Adapters KIT, 4x 767KE-ND
111. Pinnocchio: 1x FifoPi, 2x LifePO4 power, 1x ESS Controller, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor
112. hiroyuki.t: 1X FifoPi , 1X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
113. rudra: 1 x FifoPi, 1xLifePO4 power, 1 x RaspberryPi I2S adapter(transmitter)
114. jp2017: 1 x i2stopcm
115. stones: 2 x FifoPi, 2 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S to PCM
116. adelias 1 x FifoPi
117. ngocpham: 1xLifePO4 power
118. marcus1: 1xLifePO4 power
119. vanofmonks 1x FifoPI, 1x Es9028 Hat, 1x I/V, 1x ESS
120. Val33 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
121. cristianr: 1xLifePO4 power
122. triodehunter: 1x McFiFo, 1x McDualXO
123. TirNaOg: 2 x LifePO4 power
124. Dave S: Nothing
125 spm FifoPi, LifiPO4, ESS controller, Dual Mono ES9038 HAT, I/V STD and Transformer
126. quick16 2 x FifoPi
127. mige0: none
128. fm804: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB mini KIT, 1 x I2S to PCM converter board V2.0, 5 x 6" double-ended silver plated U.FL coaxial cable
129.AcDcMan1: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
130. APK : 1 x FifoPi , 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
131. miklau: 1 x FifoPi
132. Aronier : 2*FifoPi, 2*LifiPO4 power
133. JimmyThinker: 2x FifoPi , 1x ESS controller, 1x ES9028Q2M DAC HAT, 1x I/V STD standard I/V stage, 2x New RPi I2S adapter, 3x U.FL coax (4”), 3x U.FL coax(6”)
134. BachAudioDK: 1 x I2S to PCM, 2 x OPA861 I/V converter
135. Jorgen E : 1 x LifiPO4 pure power supply
136. Patjr : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
137. markhw4: 1 x McFifo, SMD XO adapter kit, 4* ADM715X ultra-low noise LDO PCB (free)
138 ollux: 1*FifoPi, 1*LifiPO4 power
139 TioFrancotirador 1*FifoPi
140 Tml: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
141 iggy111: 1x McFiFo, 1x McDualXO, 1x LifiPO4 power
142 kirks: 1 x FifoPi , 2 x LifiPO4 power, 1 x ESS Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
143 prohvesor: 1 x LifiPO4 power
144. derekv: 1 x FifoPi, 1x Dual Mono ES9038Q2M DAC HAT, 1 x Transformer I/V PCB mini KIT
145. aguaazul: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
146. Supersurfer: 3*FifoPi, 2*LifiPO4 power, 1*EssController, 1* Dual Mono ES9038Q2M DAC HAT, 6* 4" double-ended silver plated U.FL coaxial cable, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 12* SMT U.FL socket, 2* RaspberryPi I2S adapter PCB/connector package, 4* ADM715X ultra-low noise LDO PCB (free), 1* I/V STD standard I/V stage
147. CAAD: 1* FifoPi, 4* ADM715X ultra-low noise LDO PCB (free)
148. atom6422 : 1 x FifoPi, 2 x LifiPO4 power, 1 x EssController, 1 x ES9028Q2M DAC HAT, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 2 x transformer I/V PCB mini KIT, 1 x OPA861 I/V converter, 1 x I2S FIFO II (I2S) KIT, 2 x Dual XO II Clock Board without XO and socket, 1 x FIFO II isolator board mini KIT (finished), 1 x FIFO II isolator board mini KIT (unfinished), 1 x S/PDIF Interface Board for FIFO II, 1 x I2S backdoor KIT for S/PDIF board, 5 x Battery Management board PCB, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free)
149. johnyn: 1xFifoPi, 8 x 4" double-ended silver plated U.FL coaxial cable
150. acg 8 x LifePO4 power
151. RonR: 1*FifoPi, 1*I2S to PCM, 1*ESS controller, 4*U.FL coax (4”), 4*U.FL coax(6”)
152. Raj1: 3 x LifePO4 power
153. alazira1: 3 x LifePO4 power
154. malcox11 1*FifoPi, 1*LifiPO4 power
155. Emi90: 1xLifePO4 power
156. 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
157. diyiggy : 1*FifoPi
added SMD XO adapter kit to line 137
92 cv: 2 x FifoPI
127. mige0: none
152. Raj1: 2 x LifePO4 power
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
142 kirks: 1 x FifoPi , 1 x LifiPO4 power, 1 x ESS Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
Line 142 changed. LifePO4 decreased from two to one.
8. szczemirek 1 x FifoPi + LifeO4 pure power supply + Transformer I/V PCB mini KIT + I/V STD standard I/V stage
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
115. stones: 2 x FifoPi, 1 x LifePO4 power, 2 x Ess Controller, 1 x ESS controller extension kit, 2 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x I/V STD standard I/V stage empty PCB, 1 x transformer I/V PCB mini KIT, 2 x LT3042 low noise regulator PCB, 1 x I2S to PCM, add UFL cables if needed
127. mige0: none
Of course you can do it manually as test mode or use a simple design if you just need a single battery rail. However it is almost impossible to do so if you need a multiple battery rails and different voltages for the whole system. That's why I designed this LifePO4 power supply.
For a daily using system, we will need battery charge/discharge management,operating control, monitoring, protections and timing, all this kind if things, not only batteries.
LifePO4 power supply has 4 isolated battery rails and one linear voltage rail. It's a completed super high quality power supply solution for the whole system. I really can not implement all these features with a simple and a cheap design. I have been using this LifePO4 power supply in my main system for quite a long time, I'm very happy with it, sound quality, system integration, operating, everything. If you really care about the power supply quality, I have to say this is so far the best LifePO4 battery based power supply solution.
Regards,
Ian
I fully agree with you, and thank you for sharing the LifePO4 power supply design, so I can DIY my LifePO4 power supply. This is really not an easy thing, I have failed several times, so your price is really reasonable.
However, in fact, LifePO4's charge or discharge boards and other function boards have been widely used for applications such as electric bicycles, toy airplanes, etc., and a large number of cheap semi-finished products can also be purchased from Taobao or ebay for applications. If you are willing to do so, you can make up all the features on Ian's LifePO4 power supply. We can even add extra features that Ian's LifePO4 power supply does not have, such as starting the fan and alerting when the temperature exceeds a threshold. We can add more imaginable features at any time for DIY LifePO4 power supply.
Unlike Clone's original machine, it can't get the same sound quality, because the sound quality of any LifePO4 power supply still depends on the LifePO4 battery itself, not the charging circuit. I believe everyone knows, and I just point it out.
Some pictures of FifoPi
1. FifoPi
FifoPi
by Ian, on Flickr
2. FifoPi with CCHD957 45/49 MHz upgrade through the dedicated CCHD957 XO adapters
FifoPiCCHD957
by Ian, on Flickr
3. FifoPi works with Raspberry Pi
FifoPiRPi
by Ian, on Flickr
4. FifoPi integrated with RPi DAC HAT
RPi + FifoPi + ESS controller + ES9038Q2M Dual mono DAC HAT + I/V stage board
FifoPiES9038Q2MDual
by Ian, on Flickr
92 cv: 2 x FifoPI
116. adelias 1 x FifoPi, 1 pkg CCHD957 XO adapter kit, 3 x 2” double-ended silver plated U.FL coaxial cable
127. mige0: none
88. maui: 1 * FifoPi, 1 * LifePO4, 1 * I/V STD standard I/V stage, 1 * I/V STD standard I/V stage emty PCB, 4 * 2" U.Fl wire double ended, 1 * CCDH957 XO adapter kit lot of 2, 1 * ESS Controller, 1 * ESS controller extension kit, 1 * dual mono ES9038Q2 dac, 1 * LT3042 low noise regulator PCB
92 cv: 2 x FifoPI
127. mige0: none
Change to #88
Yes, the new dedicated CCHD957 XO adapters work with McDualXO.
Regards,
Ian
Looks very good ! Thnak you for that.
Does it need the 9 * X7R decoupling caps whatever the Dual,MC or FiFo either ?
How does it affect the sound please ?
Have you measured less oscillation with this total amount of caps and a particular capacitance for each on the CCHD957 ? In particular vs the other SMD XO pack adapter lot of 5 (which looks like to have less decoupling area)?
