I´ve built a 3A5 preamp
Well I dont know if it is funny...
If I ground the side where the hum is,the negative side of the filaments Elyts the hum stops.
But then the filament rises to 1900mv and it can´t be lowered.
So I guess it has to do with the filament.
Suggestions.....
The filament supplies need to be floating all the way to the socket/filament resistor. So make sure that there is no place where it is grounded earlier in the supply. What did you use for the raw supply to the regulator?
As an example - I tried to use a lm317 supply as the raw supply for Rod Coleman regulators - and I got hum. Used a regular CRC and no hum.....
Which SMPS do you use and how is it modified? And what specific parts do you use for the additional filtering?
If you could supply some links and a schematic that would be great.
I use standard 5V SMPS. I removed Y capacitors and replaced all electrolytics caps with Panasonic. Then, from 5V to 1.4V you can calculate a few RC filters.
Simple as that and works like a charm. No problem with SMPS.
I'm not well versed in the technical aspects of SMPS so I didn't realize there was such a thing as a "standard" SMPS. What brand / model do you use?
I'm not sure if I'm comfortable modding one of them, though. What's a Y capacitor and why does it need to be removed?
I can figure out the voltage drop, I was more interested in learning what inductor (specifically, brand and model, specs if possible) you use. I assume it would need to have very low DCR.
I've used some Meanwell SMPS (3.3v 10w) to supply heater voltage to some 26s when I was breadborading an amp, but I think their current rating needs to be de-rated by a much larger factor because, over time (several months) their output voltage dropped a bit. They sounded fine (with some additional filtering) but I was concerned about the voltage drop so, when I built the amp, I ended up going with a more traditional DC supply.
I'd like to try the SMPS again, though.
Things Ive tried today,switched the secondary side ac leds with each other.
Switched the tubes L/R.
And used my bench supply to drive the filament of the humming tube.
None of this worked lowered the hum,the bench supply only varied the hum frekvensy.
It aint a loud hum if I play normaly volume I cant hear it its betwen the songs its irritating.
So when you switched the tubes L/R does the hum follow the tube or stay in the same channel?
Obviously, if it follows the tube, you need to try a different tube.
