i need help wiring car receiver to power supply
i need help wiring car receiver to power supply with a 4-pin latching switch
my problem is with the three wires, (- black) (+ red/acc) (+ yellow/battery)
the car receiver is sony cdx-gt45u 12v 5amp
the power adapter is 12v 5amp 60w with terminal connector (-,+)
the latching switch has four pins
You can't do any harm to the head unit by wiring the switch wrong.
Why do you need the switch?
Confirm that the two center terminals connect/disconnect when the button is in/out.
If you wire the positive of the LED to the power supply terminal of the switch, it will always be on.
If you connect the LED positive to the head unit side of the switch, the LED will only be on when the head unit has 12v applied.
The LED negative will go to the 12v power supply ground.
