i need a information about STK3152
and the Circuit to build a amplifier.....
thanks all
/ Dj tamir úîéø àñøó
thanks all
Hard to find Dj BASS
you might go searching for other similar PIN
STK moduls, which have schematics.
Some results! Too good??!!??
I found this page with some STK schematics
http://members.tripod.com/valveaudio/schematics.htm
I searched with this - 950 hits!😛
http://www.google.com/search?num=30...off&q="STK"+schematic&btnG=Google-sökning&lr=
Take a modern IC amplifier.
http://www.diyaudio.com/forums/sear...id=37601&sortby=lastpost&sortorder=descending
Searched Our Forum for TDA7294
a replacement that is way better than STK.
A wellknown Amplifier Designer with very good reputation
in HIFI circles recommended this IC to me.
Doesn't cost much!
You will not regret it, if you use this instead!
here is schematic
http://home.eunet.cz/rysanek/pdf/tda7294.pdf
Another one also good, search our forum!
LM3886
http://www.national.com/pf/LM/LM3886.html
Doesn't cost much!
here is schematic
LM3886
I say TDA or LM is BETTER - (not STK)
http://www.google.com/search?q=STK+...=UTF-8&oe=UTF-8&hl=sv&btnG=Google-sökning&lr=
🙂 127 hits!
google: STK amplifier "schematic OR schematics"
Better TDA7294!!!!!!!!!
🙂 127 hits!
there is not have STK3152 in the world?????
thanks gromanswe... but i need the STK3152....not LM or TDA
Scmatic you have requested
This is all i can find about the STK chip. I was interested too but i can't figure out what is the attached schematic for. I found it on a chinese page and as long as i don't speak/read chinese... Maybe you guys figure it out and post the modifications.
Bye!
Bye!
Sorry for looking stupid in my early message. I was in a hurry. My boss was coming and I had no time to look at the schematic and understand it. You can get the SAP's datasheets from http://perso.wanadoo.fr/jm.plantefeve/comp.html.
Bye.
Bye.
lol
a replacement that is way better than STK. <--
that i believe ia a broad, bold comment,
a monolithic ic better than a hybrid? mmm
oh which STK series you referring to?
STK's come in Darlington, Current Mirror and Complimentary symmetry - lettalone bias types
i could find a superior STK to any TDA or monolithic...
Compare to STK2058IV
id say the 3152 is infact a pre amplifier ic
... ill have to look into this a bit more... wonder if it is interchangable with STK3041 or 3042 etc.... maybe the 302-000 or 305-000 ic series... mmm one must wonder...
ill see if i can unveil anything
- stay tuned - Baily
maybe pin compat with STK3042 / 3042II
just looked through my datasheet of the 3042/3042II
all pins appear to be the same in function... question i have tho is the difference in drive type... current mirror/complimentary symmetry...
look at the datasheet for theese ICs
i dont have the 3152 series with me atm, if i do acquire it ill add more info here 🙂
- Baily
- Baily
STK3122 and 3152 Datasheets
http://audiolabga.com/pdf/STK3122III.pdf
http://audiolabga.com/pdf/STK3152III.pdf
and some similiar in power IC's
http://audiolabga.com/pdf/STK350-050.pdf
http://audiolabga.com/pdf/STK350-040.pdf
http://audiolabga.com/pdf/STK412-150.pdf
and you may take a look at
http://www.audiolabga.com/pdf/STK00.pdf
Take care.
Take care.
by the way...the STK3152 I II III is a voltage amplifier driver...you will need a power darlington transistor to complete..maybe this can help you...i'm not guarantee you if it's working....sansui and yamaha amplifier is the one who make this in their maniufactured power amp...
- Design & Build
- Parts
- i need a information about STK3152
