something other than Loethers or Fostex or Jordan. What about drivers that maybe cost less than $100 a pair or maybe are available at someplace as accessible as PE or <gasp> retail?
An example I've always been interested in: Goldwood 8003/8.http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=290-379 Goldwood 8003/8
I've searched every forum and page I've come across for this one, but it looks like no one has ever used this driver.
How about some car audio drivers? I know that car audio drivers are not generally about hi fi, catering to the high SPL, high power handling, high durability needs of their intended environments, but I see them as having a few potential advantages. First off, I'm a big OB fan, and car audio drivers have specs that are condusive to OB use, even though these specs aren't generally available from the manufacturers (I infer this from the fact that probably all car audio drivers save subwoofers meant for ported enclosures are designed for sealed or IB us in doors, trunks or truck boxes, and drivers that spec out for those uses generally range from good to ideal for OB use). Second, alot of the lower end car audio drivers are bicone design, thus providing alot of inexpensive, true single element full range drivers to play with.
Pioneer makes some nice and nice looking ones (white cones with black whizzers). I've played with the 163Ps which sounded great. A little laid back for my tastes, but the deal breaker was almost nothing under 55-60Hz and a good bit of roll off even above that. They've got the new 1x4P series out now, and I've seen a kit with a pair of 164Ps and whatever the equivalent 6"x9" version is. The 164Ps probably aren't any different than the 163Ps were, but the 6"x9" version might have enough low end to be worthy.
I know other manufacturers make this type of unit, too. Even the Walmart brand, Durabrand, makes a line of them in 3", 4", 5", 6.5" and 6"x9" for no more than $10 each. I feel almost certain that these are junk drivers given the basic no brandness of them, but the primary cones look well built (though I'm not sure what material they are), the magnet structures on the 6.5" and 6"x9" ones ar of the same general size and heft of the ones on the drivers I use (see below), and the surrounds/suspension look solid, so possibly someone might fine good uses for them (they do have questionable looking silver mylar whizzers, though, so I just don't know).
I personally use a pair of Kenwood KFC6949S which are 6"x9" mica cones with paper whizzers which ran me $45 at Best Buy. I run them in an OB config that I build for another $15 or so. Even if you count my electronics (Emu 0404 sound card, PreSonus HP4 headphone amp as preamp and SI T-Amp) into the equation to account for the quality of sound, that's only another $200. I don't know any pair of retail or even direct maker speakers that cost $260 or less that are even close in quality. Step up to $300 and you can get a pair of Magnepan MMG-W, which I have to admit to coveting, sounding ridiculously good for $300 speakers, but even as Magnepan's smallest offering, they are still bigger my current baffles, have no bass at all (response basically drops off a cliff at 100Hz while I'm getting a comfortable 40Hz out of my Kenwoods), and require quite a bit more amplification than I'm using right now (probably requiring another $300 in amplifier to keep up, quality wise not to mention the rest of your source chain).
So, anyone have experience playing with any full range drivers that don't get alot of air time around here. Cheapies? Car drivers? Drivers salvaged out of box speakers someone else built poorly? Even bad experience is welcome here as it keeps others from wasting time and money on drivers that can't be redeemed from their humble origins.
Kensai
Kensai
B20
http://melhuish.org/audio/DIYBX16.html
I like the Pioneer B20 and am currently re working the cabinet for another project.
Peace,
Godzilla
Peace,
Godzilla
Pioneer B20 is mentioned in this Passdiy article. The Goldwood GW8003 is also mentioned, but the Pioneer was much preffered for $4 more.
Keep in mind that a tweeter is pretty much required with the B20, so factor in the additional cost.
The B20 seems interesting, though it looks to want to be boxed more. If it absolutely requires a tweeter, though, its kinda out of the running (I'm being a definition snob here, I guess; we are talking full range drivers after all). I wonder how it would respond to a little active EQ (I us the Emu 0404 in my current set up, mostly to tame a few peaks and to fill in the bottom end as much as I can without muddying the sound).
Anyway, I guess I'm hunting for something that will comfortably hit 50Hz or less on the bottom end and 16KHz (the apparent upper end of my hearing) at the top. I'm really loathe to use anything that'll need a sub which is a big reason why I haven't just bought a pair of MMG-Ws and put paid to the whole situation. I'd need to build a stereo pair of subs to mate to them, even if they were just a pair of wimpy 8"ers; there goes at least another $200, and we're pushing $800 now for upgrading. If I'm going to just blow a bunch of cash on new speaks and attendant electronics, I'd want to save up $1200-$1500 for a pair of MG1.6s and a nice Crown XLS amp to drive them. Until that magical day, I'll have to be satisfied with pocket change expenditures and experimentation.
What other fun things have you guys played with?
Kensai
Kensai
As for the B20's... i am currently building a new cab for them where the B20 is mounted high towards the top of the cabinet. This driver sounds dull if it's not pointed right at you. Off axis these are not 'full range' drivers IMO.
As for adding a tweeter... this is cheating but... IMO the B20 needs a tweeter to sound it's best. Crossover can be anywhere between 2khz - 22khz... this is a pretty flexible driver. But for my current project i am mounting the tweeter on the back with a simple cap and L-pad. The piezo tweeter cost about $1.50 at parts express.
With tweeter on back (hopefully this will sound good) it looks like a single 'full range' driver. The tweeter cost is minimal and you will get close to 50hz... maybe -10 or so at 50hz in my design (my guess). You also stay in budget. I think it's ok to cheat a little at this price point.
Last night i looked at my B20 and thought it looked so old compared to the new TB Bamboo.... which is also another interesting 'full range' driver to consider but it's twice the price of the B20 and doesn't go as deep... tweeter optional.
I look forward to comaring these two speakers.
Peace,
Godzilla
Peace,
Godzilla
it seems to me to be asking a lot of a smaller full ranger to fulfill bass needs on an OB. may will have some bass, but will it be enough?
perhaps some sort of guitar drivers could work. i know some use large coaxial drivers with luck. though, they come at a price.
i'd think you would have better luck worrying about he mids and such, then picking up a knight woofer for the bass end of things, as they come really cheap. just know that OB bass needs room to breathe.
there are vintage drivers as well. many of the older consoles had open backed speakers and drivers to match. i have some older drivers from that type of set up. nice, but really haven't spent much time with them.
anyway, lots of options. but i have to wonder if cheap car speakers really offer all that much. then again, if you're enjoying them, there must be something to it. then again, compared to a decent full ranger, i'd have to wonder what you'd think.
You might consider the $5 Apexjr ribbon tweeter with just a cap for crossover on the B20.
Going up to the $260 a pair range, you might really want to give Visaton B200s a look. No need for elaborate electronics here, and T-Amp will power them. With the right baffles they can meet your bass requirements.
I've recently entered the world of full range drivers and have become familiar with the popular drivers through this and the full range driver forum. After browsing through the Fostex line at Madisound I remembered seeing a driver a while back that looked similar to the Fostex FE series drivers. Low and behold I found the pair of drivers I was looking for - they were the front door speakers from a Subaru Impreza (also made in Japan 🙂 ). Their overall diameter is about 6 inches, with the cone being about 4.25 inches in diameter. The markings on the back of the driver indicate that it's 4ohms, can handle 30W max, was made in Japan, and has FE040 in the numbers on the back plate - definitely made by Fostex.
They sounded kinda blah in the car from what I remember, and don't seem to have very good high frequency response, but they do have decent bass capability. I'm sure you could snag a pair of these drivers for cheap on Subaru car forums where owners replaced the factory speakers. Maybe other Japanese car makes use Fostex drivers too?
Please, tell me about the knight woofers. I was given a web link to an online retailer, but I don't know anything about the company. Have you used one of these? I'd be interested in your take on them.
The 15 incher sure seems well suited to OB. Very nice price as well. I was planning on using Eminence Beta 15s, but these might be better and cheaper.
Thanks.
Paul
BWRX,
Now that's the kind of stuff I like to see. I'm all about repurposing stuff. I figure there's not much worth having if you haven't customized it to your needs or at least modded or tweaked it in some way. These seem like they're probably too small for full range by my def, but I bet you can get them to do everything you'd want from 100Hz up and sound pretty good doing it. I'll keep my eyes open for discarded factory speaks, especially from japanese cars now.
one1speed,
I don't really want a "smaller" full range driver. The smallest I've worked with are those 6.5" Pioneers, and while they were good, especially for the price ($25/pr at retail), they were not satisfying (low end was really only good down to 60Hz no matter how fancy I got with my EQ and definitely EQ required to elevate the upper mids and highs out of the mud).
I played with the 8" woofers out of a pair of Yamaha NS-6390s in OB for a good while in full range with no help, and they were actually what got me into thoughts of single full range drivers as they did fine, espeically with a touch of EQ from 40Hz up to about 5KHz (which only leaves out the upper 2 octaves which are mostly just harmonics from more common tones). But, since they weren't really designed to be full range, I eventually tired of the super thin top end, regardless of how smooth and detailed the mids were and how well they imaged (first experience with trying to properly set up a "point source" too; really working up a body of more esoteric opinions in my audio reproduction, here).
My current drivers are those Kenwood 6"x9" which are not small, either. I'm not so sure about the effects of the oblong shape on sound quality, but at least they sound good and have adequate bass for my needs with minimal EQ (mostly taming peaks rather than needing to pump up the bass to artificial levels). I've been most interested in more conventional round drivers at the 8" or higher levels to get adequate bass, thus I mention that Goldwood model earlier. I've looked into pro drivers, seeing there are some 8" and 10" models that have whizzers, but even at 10" its hard to find any with an Fs below 100Hz, and there's no way to get a decent response at 50Hz or lower on OB with a driver like that.
I'm theorizing (with mathmatical background, mind you) that the sweet spot would be a 12" driver utilizing a whizzer or some other additional cone structure work to provide high end. The driver would need to have a Qts around .7 to be optimal for OB config and have an Fs at as low as possible. I know there are trade offs to be made here since most drivers that have very low Fs are built as subwoofer drivers and that the heavy duty construction of such drivers would destry any chance of such a driver being able to provide any response in the upper 3-4 octaves even with a well designed whizzer or whatever. Thus the need for the really big primary cone.
Here's a kinda ridiculous example: http://www.fostexinternational.com/docs/speaker_comp/pdf/fw800n.pdf
This thing is enormous and really expensive, but look how close it gets to what I'm thinking. Has a Qts of .69 and an FS of 18Hz. Fostex also rates it up to 1.5KHz in useful response. How much more high end could you get with an emphasis on designing a secondary cone structure? How about if the driver was large (12" or 15") instead of ridiculously huge (31.5") so that you could be more concerned about the high end instead of "how the heck do we move and control this ridiculously oversized cone?" Yeah, I'm sure such a thing wouldn't be cheap like I've been talking about, but still, I think it could be done and sound good doing it. It would just be nice to have drivers designed to give "true" (yes I know I'm being egocentric imposing my definition here, but just indulge me) full range from something approximating a point source without the need for esoteric, expensive, difficult to design and construct enclosures to reinforce the bass and/or compensate for the driver's unique short comings.
I guess I'm after reproduction that:
1) has no crossover
2) is dipole (I feel this is the most natural sound, as well as beeing the easiest to integrate with any room and giving the best "sense of space"; just my personal opinions here)
3) is reasonably close to being a point source
4) this is optional, something I've more recently started to think of, possibly possessing little/no baffle (is this what transmission lines are for? I need to study that a bit)
If I'm going to be using dynamic drivers instead of selling my wife for the planars I love, these things seem to be the means to getting closest to the sound, in my limited experience.
So, where do we go from here?
Kensai
one1speed,
1) has no crossover
Kensai
>>>If I'm going to be using dynamic drivers instead of selling my wife for the planars I love...
Sell your wife!
Sell your wife!
12s with whizzers and high qt? The best bet for that sort of thing would be looking at vintage speakers I would venture.
As to the night woofers, I really meant Madison, as I believe that is the name of the company, Knight being a model. They were recommended to me a while back and I know they offer a decent pro sound selection. Don't know much about them, but I did email them and they recommended not using the bottom line woofers for what I was after. In the end, I realized I didn't really have the room for large OB woofers.
Kensai
You've got a tough battle here. I would agree that looking into vintage speakers may be the way to go. I have some 8 x 12" Telefunkens (Isophon) that may work for what you're after, though I doubt they'll go really high or really low.
The idea behind an oval speakers is you get the bigger bass from the larger part of the cone, yet the tight mids and highs from the smaller part. Well, I'm sure it doesn't work quite like that, but you get the idea.
Realize that, in general, the larger the speaker, the better the bottom end, but you tend to lose it on the top end. I remember reading where the Hurdy Gurdy Man switched from a 10 or 12" EV full ranger to an 8", and said the mids and highs on the 8" were much better. So that could be an option.
So, my first recommendation would be to go with one of the Madison woofers and a 6.5" or 8" full ranger on top. You could go smaller depending on the crossover point. But, you could just cross the woofer in and let the full ranger run full range and roll off naturally.
Or, I would look into the Visiton B200. That seems to be the ticket for OB, though a bit pricey for you. However, it seems to be about the only thing I recall reading about that would fit the bill to a "T".
One other thought is the cheaper Pioneer 8" driver from Parts Express. At $25, it may be work trying out.
Best of luck.
Kensai
Best of luck.
morbo said:How about the CSS FR/WR125? Any reason they are left out of this discussion?
BWRX said:has FE040 in the numbers on the back plate - definitely made by Fostex.
The EAS16P is a standard National (Panasonic/Matsushita/Technics) designation, so no, these are not made by Fostex.
dave
Tweeker said:12s with whizzers and high qt? The best bet for that sort of thing would be looking at vintage speakers I would venture.
My 1st thot as i went thru the post is that he wants something like a Goodmans Axiom 201/301. In good condition thou they make a Visaton B200 look inexpensive -- the B200 is an outstanding driver. On a big enuff baffle it definitely does bass, and the top is good if a bit "head in a vise" -- be interesting to see what they did with phase plugs
dave
planet10 said:The EAS16P is a standard National (Panasonic/Matsushita/Technics) designation, so no, these are not made by Fostex.
dave
That would explain why they don't sound very good then 🙂 Thanks for that bit of information.
- Full Range
- I know there are more full range drivers . . . what about . . .
