firstly, I couldn't be bothered with bracing.. the box isn't all that big really, like I said before... the largest area with no bracing is about 35cm X 35cm... so meh 😛
as for mdf, yes, I know it makes alot of dust... I cut 4 holes for 8 inch woofers in 25mm MDF using a router... AND two 100mm ports, AND I rounded the edges of the boxes.. 😛 see my webpage down there for pics... assuming it still works 😛
lol, they look funny with those drill holes 😀
yeah mike, my mate has so far built one, but he is using the 12" JL sub, it still sounds awesome 😀 never heard anything like it before 😀 😀 😀
will be building my basshorn this weekend with the pioneer 😀 ill share some pics shortly 😀
hey MIKEY!!! just wondering if the horn is supposed to be 350mm wide internally or externally?? thanx...
what horn!😕
yes you do post alot of boring pictures
Theres no real 'break in' that I know of with subwoofers apart from the first times.
and no, the frequency response will hardly change from unbroken in,to broken in so its as good as it will get. Just wait for your mind to accept it and get used to it,youl enjoy it til you hear a decent sub then youl be unhappy again😀
these subs take abit for them to soften up fully 😛 and seeing as I have 2, I could feel that one was still firmer than the other... 🙂
and, the Pioneer horn... how wide is it?
that one: http://www.diyaudio.com/forums/attachment.php?s=&postid=572968&stamp=1108116671
ah its a really old design
Il see when i get home tonite if i still have the plans or I can refold it
you could probably get away with making it 35cm internal and seeing what happens
Safer to remodel it and see.
Tsw305c?
Fs 30
Qts 0.4
Vas 60L??
Tsw305c?
Fs 30
Qts 0.4
Vas 60L??
TS-W305C
Revc: 3ohms
Levc: 2.107uH
Fs: 32.7Hz
Qms: 15.059
Qes: 0.348
Qts: 0.340
Vas: 51.449 L
Xmax: 9.2mm
SD: ????
Revc: 3ohms
Levc: 2.107uH
Fs: 32.7Hz
Qms: 15.059
Qes: 0.348
Qts: 0.340
Vas: 51.449 L
Xmax: 9.2mm
SD: ????
SkinnyBoy said:TS-W305C
Revc: 3ohms
Levc: 2.107uH
Fs: 32.7Hz
Qms: 15.059
Qes: 0.348
Qts: 0.340
Vas: 51.449 L
Xmax: 9.2mm
SD: ????
Funny how they quote the specs with so many decimal point accuracy,when unit to unit differences will be +-10% for Fs and Vas 😛
Sd : ~490cm^2
AHAHA I have those exact subs and 2 of them in a 1.5 cf box tuned to 28-29hz they sound ok but I think Im gona need more out put soon😀
well, i finally got the money to buy the 305c
they WERE selling them for $179 in JB-HIFI but thanx to skinnyboy who told me that he got them for $95, i managed to get the same price, so im happy!
My mate is bringing around the wood tonight, so ill keep you posted and take pics and tell you how LOUD and LOW this thing is capable of 😀 😀 😀 😀
- Subwoofers
- I have sinned... :p
