I have a logitech subwoofer....don't laugh
Fully agree with GM:
b 🙂
PS:
Logitech Z-2300 : The Last of the Titans - Speakers - Home Audio
Z-560 and Z-2300... - Logitech Forums
Logitech Z-2300 [ The Last of the Titans : Review] - Logitech Forums
they did agree that they supplied W8-670C drivers for Z-560
Note: Normally people confuse this bass driver as used in Z-680, Z-2200 & Z-2300 with the Tang Band W8-670Q model.
Though both units look near identical, Z-2300’s bass driver is different from the W8-670Q in the rear section.
It became absolutely certain when my friend’s Z-2300 bass driver went dead and I have to personally contact TangBand via email to ask the model of the driver used in Z-2300 & its price. I also send them the above pictures of the driver to help them identify. To my surprise, they replied after inspecting the pictures sent to them, that this bass driver do not belong to them or in any way represent one of their models. But they did agree that they supplied W8-670C drivers for Z-560. So, you see Z-680, Z-2200 & Z-2300 are not TangBands. Prior, I was also the victim of this case.
Logitech Z-2300 Subwoofer Disassembly | blog.jseaber.com
I had actually read that sealing the sub might make it go lower...I wonder where I read that???
Well, some speakers are ported up around 40 or 50 or 60 Hz. They die below that, because the wave from the inside can kinda leak out and cancel the wave from the front of the cone. Sealing those units might bring up very low stuff.
So, all I could hope to achieve is lower spl and higher bottom end? That doesn't seem like the best of trades...
What you gain is more faithful transient response & less ringing. How much that matters depends on your individual taste a lot.
as it stands now...I'm really happy with the sub. I think the Pioneer MCACC system is really quite helpful when setting up a theater room. When I had the sub up front under the center channel is sounded small...now that it's behind the couch, it sounds really big and smooth. I am almost wondering why I would need or want 2...yet, I will likely get another one.
