I got my Viewsonic VP150M in the mail today - having trouble
Hey guys, I got my LCD in the mail today
It did not come with a power supply, it says on the screen "Needs 12V DV round", does that mean that I need a 12V DC adapter? If so, will any 12V DC adapter work? Am I going to have to buy some special part?
Anyways, i took off the back and spotted the brown flex cable. I think this LCD is going to be a bit tricky to dismantle, but I should be able to get it done.
Any help would be good
Well, any power suply with work, if they have the good plug, and if the amp are ok.
You allways need a power suply that provide equal or more amp than the device need.
So if your monitor needs 12VDC with 100ma (milliamps), well your power suply must be 12VDC with 100ma or more.
And round well I guest this is for the type of plug
Hmm...
Backlight is dead on my LCD
I have a million and one PC power supplies, but this monitor takes a round connector.
The PC power supplies only output a connector for the motherboard, and ones for the hard drives and things.
How do you hook one of these up to an LCD monitor?
OK not to but in or anything But, OK so you wanna get this monitor working, do you have a scaraficial barrell( round) plug off mabe a old dead PS, if so clip the wires long and connect to the pc power supply with electrical tape. IF not then go to radio shake and spend 10 bucks and get one( granted it needs the proper voltage amps( you can go over on amprage) and you should be set. Where did you get the monitor? ebay? how much ? you said it has a dead backlight? talk to u L8er
