You are lying about an associate of mine. Please, no libel.
Wait are we talking about he Machina Dynamica guy here? 😕
Eh yes.... what about the power cabling in the wall and the stuff that goes from the house and down the street? You might be missing some further detail unless you re-wire those links.
Yep thats the next project. Wind turbine generator powered electrical system, charging large batteries, cabled with Cardas to the outlets from the batteries 😀
'Magic Pebbles' are pretty far out. Designed by an Aerospace Engineer.
Yeah, designed by an aerospace engineer who also claims that placing photographs of yourself in your freezer improves the sound of your system.
se
se
I think placing photographs of your avatar, in my freezer, will improve the sound of my system. Come to think of it, erasing the memory of seeing your avatar would improve the sound of my system.
Try Oyaide 1430-22awg wire.
UL and CSA approved? The circle of conspirators widens....
These discussions go round and round so many times it's easy to forget, are the high tech measurement systems being compared to audio applications also making a single measurement across a decade+ bandwidth? In my field the bandwidth of interest is normally +-1% of carrier, 10% maximum. I wouldn't expect contact issues giving rise to harmonics, for example, to mean jack squat in these apps because they never make it past the tuned front end. Is the comparison really apples-to-apples?
The other twin is prettier.
I think placing photographs of your avatar, in my freezer, will improve the sound of my system. Come to think of it, erasing the memory of seeing your avatar would improve the sound of my system.![]()
My goodness.I wonder how that avatar will look if cryo'd
se
UL aproved.RoHS compliant.Insulation 300-600V,105*C,PCOCC-A copper 🙂
Made in Japan
bad idea
batteries not a good idea... too noisy
se
I'm afraid cryoing Mr. Braudigan's head will get you no farther than Hemingway's.
answer
Yes
<snip>
These discussions go round and round so many times it's easy to forget, are the high tech measurement systems being compared to audio applications Is the comparison really apples-to-apples?
<snip>
Yes
Oddly enough, it's not about temperature. It's about the freezer compartment of your refrigerator. They appear to possess some sort of temporal time warp that recombobulates all the things that were discombobulated when a photograph was taken of you as a child.
This by the way is a Peter Belt tweak, and Geoff's been a Peter Belt devotee for some time now.
se
Apparently, I got censored for asking that the topic be returned to wires and connectors.
However, ever onward. I hope that others will study the two texts 'Modern Electrochemistry 1 and 2' and give me some input to what might be applicable to the discussion here. I just went through part 2 and it is mostly about solutions, and processes of different kinds. Chapter 7 has a short footnote on metal conductivity, but that is all that I have found, so far.
Cool. So what RF fields, as I do in the audio domain when playing with tubes, are single measurements made across three decades to better than 120dB down?
Scott, I see where you got your info. Now are you saying that what he did for a living in the past was not real?
When you're taking money from people and tweaking their systems by having them call you so you can tap on a pie tin, I don't think what you may have done in the past is of much relevance.
se
Still off topic, but funny: Richard Feynman did have some interesting things to say about sensory deprivation chambers and LSD. Not sure what that would do to the sound of your audio system, but supposedly he sure heard some interesting things in there!Yeah, designed by an aerospace engineer who also claims that placing photographs of yourself in your freezer improves the sound of your system.
se
Back on topic, the questions regarding the applicability of comparisons between high end lab equipment and high end audio equipment certainly have some validity. Instrumentation amplifiers do strive to be as clean as possible and minimize known sources of noise, while audio amps sometimes do not! IMHO, this seems an overt critique of poor design in some audio equipment rather than a question of whether instrumentation used for analog signal amplification in a laboratory setting should be a source of understanding potential noises in audio equipment.
As much as I have tried to transfer what I know from instrumentation design into the audio equipment I have built, I definitely understand that there are many things that people like John have to offer back to me from a different perspective (most recently the Holm contact book, to cite a specific example). I would be a fool if I summarily thought my experience in a tangential but related field automatically trumped the experience of someone working in this field. Regarding the specific question of signal cables, however, I have a great deal of experience with instrumentation using different cables for very specific purposes, thus the reason I have been adding my $0.02. On this topic, I have a pretty decent background and can offer (what I believe to be) reasonably informed commentary.
The question of power cables, I simply dismiss as ludicrous for a variety of other reasons. The immediate ones that come to mind are that no advocates of the high end power cables have discussed mains wiring (at least that I am aware of), or the much cheaper and much more valid alternate option of filtering incoming AC power before it gets to the components. Without both of these analyses in place, I can't fathom why I should begin talking about power cables!
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
