Bruno
Was the published measurement data done with some like this? Audio Precision : High Performance Audio Analyzer & Audio Test Instruments Will you tell us what you use?
As the little blue AP logo on the graphs suggests, indeed we use an AP, a SYS2722 to be precise. Actually we've got 3 of them, but one suffices
Bruno, I just sat and read the datasheet on power pins from the SMPS and thought of a possible improvement there.
You have the pins numbered with their function, but since they are all nicely colored why not add the color of the cable as an extra column?
And another indirect question:
The reason for multiple cables with the same function is for simplicity of avoiding some larger cables so that all can be connected with the nice molex connector?
I'm planning the soldering to combine the PS-cables so I can drive two modules from one SMPS, and soldering 7 joints by combining the grounds and the voltage outputs means less soldering for me than If I connect each pin without combining. But since I didn't design the module I might as well ask if that would be a problem =)
// Olle
// Olle
Very nice!
JBL LS80.
Goophy, anything more to report?
Hi all,
The discussion about enclosure seems to have died, but i did not.
- hifi2000/modushop enclosure, the slimline 01/350 (internal 415x350x40)
- 6x nCore (Linkwitzlab Orion) upside down for better cooling
- 1 or 2x smps400 (smps600 wont fit for its heigth)
- backside with all Neutrik Powercon/Speakon and jack/xlr connections
- modular front with changeable modable black plastic plate
What do you guys think?
So, what do you guys think?
When I wrote the data sheet I wasn't even aware they were going to use different colours. It's worth adding.You have the pins numbered with their function, but since they are all nicely colored why not add the color of the cable as an extra column?
The multiple pins are indeed parallelled.
1. I believe you.
2. That is (close to) unbelievable.
I presume you mean at the listening seat several feet from the speakers, not standing close to the speakers? Or both?
With my ear actually ON the speaker cone....
Hi guys !
I`m in need of a XLR to RCA adapter to connect my unbalanced pre amp to the Ncore amp with XLR input .
I want to be able to use my preferred RCA cable ( very costly and lasertech welded)this means that I`ll not be able to mount a XLR directly to the cable end! Therefore I need a XLR to RCA adapter solution.
I already have a std XLR to RCA adapter, but I´m not sure if it`s internally wired correctly, to be used in this setup.
Any suggestion of how the XLR adapter should be wired internally ???
PS: A drawing of the solution would be very much appreciated .
Regards Gonzax
Regards Gonzax
I will be placing an order for 5 NC400's and 3 power supplies, but not until I have all the funds together, in about 1 to 2 weeks. Will I still get on the wk11 run?
Sorry for the confusion gillib. Very nice build.
Yes, will be no problem. We still have 70% left of the WK11 batch.
Hi guys !
Regards Gonzax
Gonzax
Cardas and Neutrik both do a similar adapter and each one should work just fine.
The wiring is the same as the diagram in the NCore datasheet which shows how to connect an unbalanced (RCA) source to the XLR balanced input preferred by Bruno.
Gonzax
Gonzax
Parts ConneXion - The authority on hi-fi DIY parts and components do the Cardas @ $69 per pair and the Neutrik part ref is NA2MPMF at Neutrik - Audio - Circular Adapters I would think that the Neutriks are much cheaper.
Cheers. John
Any adapter will degrade the signal to some extent. Only you can decide if this is acceptable. Regards
John
I agree and we at acousticimagery - HOME supply our D400M power amps with a ViaBlue RCA-XLR cable so that there is no need for an adapter. But, Gonzax did say that he wanted to use his favourite RCA-RCA cable so maybe he should decide whether the best option is to use phono sockets on the power amp in accordance with the '2nd best' option in the datasheet for NC400.....a sonic conundram!
I personally, would always have an XLR input to any power amp. Our preamp has RCA output sockets for purely practical reasons in a 'one box' design. Future plans include a fully balanced pre amp with XLR outputs.
Architect, the fact it doesn't take a SMPS600 is a deal breaker for me. Otherwise, a good solution for active crossovers and/or HT.
John
Actually we`ve just decided to avoid the XLR-PHONO adapter, and go for the phono & xlr socket solution instead Why I didn`t think of that in the first place is a mystery
Regards Gonzax
guys, I made a .dxf file with the NCORE logo exactly as depicted on the Hypex website for anyone wanting to CNC engrave that on the face plate, but I'm not sure if I'm allowed to post it. should I?
For DIY projects this is OK.
Ask the Big Boss and offer him the file too, and ask for a pair of Ncores in return....
Well if that's all it takes I'm in. Let me know and I'll fire up the CAD computer. Yes, I'm serious.
- Class D
- Hypex Ncore
