Go into device manager and delete the unknown HID (you might have to use «show unknown»).
Then unplug the PSC and restart the PC. After you have restarted the PC, go into system 32 and disable the three drivers (rename them from .sys to .bak)
Then plug in the PSC and let the drivers reinstall
Johan-Kr
Johan-Kr
okay, I tried your suggestions and encountered the following:
whatever is going on behind the scenes, this might be a viable workaround....
Thanks!
- device manager only let "deinstall" the unknown device, no delete
- then restart
- moving or renaming files in ...\system32\drivers needs special permissions (being admin is not sufficient)
- nevertheless, replugging PSC after the reboot worked flawlessly 🙂
- PSC is even recognised on a second win10 PC now :-D
Thanks!
