Hypercube Loudspeakers
Special relavity defines what is not possible. It also
defines a space outside the the light cones that
can only be reached by exceeding light speed.
That such a mathematical space exists is true but
that tachyons are said to pervade it is a conceit.
Whatever, we will simply never, ever, know.
rgds, sreten.
I don't see why this shape would be particularly difficult to make, one could always make a cube, cut the corners off, slap some more wood on the cornerles corners and then use a router in a simple jig to get the edges flush with the relevant sides.
I think a double blind test comparing these against a square and golden ratio box of equal volume would be interesting, with and without radiused corners and so on.
i'd give the shape a go because it looks interesting and would be easier to make than a sphere, but I'm no audiophile.
That superluiminal tunneling is fascinating. Sorry I have been working on the software to help folks calculate piece sizes from the desired internal volume. I'm doing it both ways: calculate external sizes from internal volume inpiut, and calculate internal volume and external piece sizes starting from outer square side input.
According to relativity nothing travels faster than light...but the superluminal connection between quantum-entangled particles is well established (ie Bell's, Hypothesis). Unfortunately, no one that I know has found a way to transmit any more information that way than: if we measure this particle's spin as *up*, then the distant one's spin must be *down* and vice versa.
Oculi, we must be careful in visualizing the shape -- many confuse it with the cuboctahedron which can be made the way you are saying I think. They look similar in photographs, except the cuboctahedron has no rhombi -- just squares and triangles. But often you see one with the square surrunded by triangles and it looks like the square-truncated RD
MuddJester, you raise excellent points about stiffness. R. Buckminster Fuller would have had comments about the stiffness (tensegrity etc). When you put these things together out of thin panels they are hilariously floppy until the last couple of pieces go in...then they are really tight and strong.
Apologies if I misunderstood your post, Oculi. The cuboctahedron is the dual of the rhombic docedahedron. They are easy to tell apart when the RD is non-truncated...but when you square-truncate the RD it can look from some angles like the cuboctahedron.
Cuboctahedron - Wikipedia, the free encyclopedia
Rhombic dodecahedron - Wikipedia, the free encyclopedia
I was going off this photo
which looks like a Cuboctahedron to me, does a Rhombic dodecahedron have zero square faces?
My method (of making a Cuboctahedron wouldn't work anyway as unless you were prepared to do a lot of work (and it looking very untidy) it would end up being a truncated hexahedron.
Foam Core Hypercube with TC9FD
This speaker is perfectly suited for foam core: fast and easy to make, and hardly uses any material. The shape of the speaker uses very little foam core that I think a 30in x 20in sheet could probably make 4 or 5 speakers. I am using the Vifa TC9FD which I know the response of very well in a variety of cabinets. I made the square baffle 4.62in and all the other edges 4.00in. I made 2 patterns: a triangle and a rhomboid then used them to cut 4 triangles and 8 rhomboids, then a square. I added a triple-ply cardboard layer behind the baffle for screws to mount the driver. Cutting the pieces took about 15 minutes, hot melt gluing them another 30 minutes. The speaker was done in under an hour. Like Tesserax says, it is a floppy contraption until the last few panels are glued in place and then it is very stiff. Hot melt glue is the way to go - very fast and easy - only 2 sticks needed.
Here is a photo of the completed speaker - it has a nice flat for resting on surfaces. I wish one of the surfaces would allow it to slightly tilt up, but no luck there. It tilts either down or is level.
attachment.php
Measurements were made at 0.5m distance, amp is custom TPA3116D2, mic is Dayton UMM-6. Software is REW 5.0 with HP Mini110 netbook. Here is the measured frequency response and harmonic distortion at 0.5m away with no stuffing, there is a resonance peak that is not normally there with other cabinets. I think this looks a lot like a good sealed cabinet, and a lot like the Nautaloss in smoothness, but the Nautaloss is smoother. You have about 4 or 5 dB baffle step loss below 1kHz, and the diffraction effects appear to be minimal:
Here is the measured frequency response and harmonic distortion with loose polyfill stuffing - smoothed out some of the peaks and dips. The stuffing really does reduce the harmonic distortion levels though, which are excellent and typical of the TC9FD:
Here is a comparison of the response with and without stuffing - the no stuffing case is very similar to with stuffing - not too bad. The cabinet does indeed do a good job of controlling major typical boxiness resonances internally:
Here is the response (no stuffing) showing the phase - which shows a dip at 1.7kHz that causes a phase discontinuity because the phase was so close to 180 deg already, the dip is flanked by a couple of large peaks, with the bigger one at 2.2kHz (this level would be audible with certain songs). This must be the cabinet's characteristic resonance frequency. Probably latex caulking and a second layer of foam core for constrained layer damping would clean this right up:
Here is the impulse response with stuffing (without looks the same) - very clean:
How does it sound? Very nice - similar to the Nautaloss in character, but a lot easier to make. The claim that this speaker does not need any stuffing is valid. I would use it just to reduce the distortion though. I find the sound to be very pleasing and would be great if used in a FAST with a subwoofer crossed at say 200Hz. A fun build, highly recommended! Great desktop speakers to use with a sub.
For reference, here is the TC9FD in a Nautaloss II:
Oculi, the rhombic dodecahedron normally has only rhombi (12 of them) except when you truncate it. When you truncate back one of the 4-edge (pyramidal) points it makes a square baffle plate. You can see from #113 that the rhombi can appear to be squares when seeing them from a slant instead of straight on.
In a word, wow, xrk971. I have never used foamcore and had no idea it was such a fast prototyping material. Obviously I need to get out more often. Can I ask your opinion of what differences, if any, you have noted with speakers in the past between wood and foam core in terms of sound quality?
You can tilt it up though. When I make this shape, I like to situate it so the woofer is facing up at a 45 degree angle similar to the effect caused by the speaker stands I remember seeing. Granted, with light cabinet materials it can be unstable with the weight of the driver tending to roll it if jostled. But the woofer can also be faced parallel to the floor as your picture shows.
I am biased as I have only made speakers out of foam core (except for one which used a masonite front baffle). I think they can sound excellent if braced, and in some cases, if constrained layer damping (CLD) is used. For CLD, I use 2 foam core layers and latex caulking in between. This can substantially reduce resonances that lead to harmonic distortion. You can see from my measurements that the HD is quite low above 200Hz. Below 200Hz, the foam core can buzz more - but a lot of that is also the driver having lots of distortion due to large cone movement. My tractrix synergy (Trynergy) horns sound amazing:-55dB HD from 200Hz on up and 110 dB sensitivity. Those have to have CLD to work right though.
http://www.diyaudio.com/forums/full-range/261427-presenting-trynergy-full-range-tractrix-synergy.html
Thanks, George. 🙂
Thanks for the arxiv link to the teleportation paper. I had not seen this one yet done with solid state crystals and diode lasers - much more amenable to miniaturization for a quantum computer. Back in the day, they did this with complicated Bose Einstein condensates and finicky optical traps.
I like the look of the Hypercube and feel that this project deserves the matching stereo pair. Given that it consumes only 1/4 of a sheet of FC and another TC9FD, and one hour of time. I think it's a no brainer to make two and bring to the office as my desk speakers. It is a great conversation piece if anything.
