I don't know if you've looked at the "phase shift amplifier." This will also be key to proper nulling.
Use your scope channel 1 to monitor and sync on A3 TP4 and probe TP1 on the second channel. Use the 339A generator as the source. You should see a sine wave of equal amplitude and 90 degrees phase shift re TP4 at all frequencies. Any departure from 90 degree offset means a problem problem in frequency resistors (or caps) in either generator or phase shift amplifier. If you have a frequency counter, you can use it to confirm oscillator frequency is correct. If no counter available, the external generator might help distinguish.
Talk to you tomorrow.
I just now considered more carefully the data you provided in post #73. The details of TP1 don't seem plausible in a functional U3B given the values of R21 and C8, irrespective of waveforms presented by U2. I was going to ask for corroborating evidence by asking about waveform at R21, but it's generated by part the same opamp. Same story re TP2 and U5.
You can poke around for confirming symptoms, but both are likely failed.
Sorry for delay,watching F1 race. On A3 TP4 andTP1 two sine wave signals equal amplitude but not at 90deg phase shift, I would say only about 60deg. Signal on pin 3 of U1 is about 3dB down on TP4. I have a counter also in the scope, 339A osc is slightly low on CAL position ie 1kHz is 980Hz but this is easily corrected with the frequency Vernier.
On A4, TP 3,4 and 5 sine wave similar amplitude. Tp1 garbage TP2 DC only. Circuits from Tp1 and TP2 drive E1 and E2 leds so DC would make more sense than garbage. Also the three trim pots do nothing as far as I can see
I have a friend who is an avid F1 fanatic, so I fully understand.
I should have specified more carefully. That you don't observe 90 degrees is concerning, so I'll elaborate/belabor this point.
This circuit is a so-called all-pass network. If you examined phase shift versus frequency, it would be 0 degrees at low frequencies, 180 degrees at high, and in fact it's exactly twice the phase shift the phase shift produced by the R-C lowpass filter driving U1 pin 3. So it should be 90 degrees at the lowpass "corner" frequency, i.e. = 1/(2*Pi*R*C). So in the 339A at 1kHz, R is R1=28.7K, C is C3=5600pF. The formula yields 990.26 Hz. So I'm at a loss to explain what you saw. I'm hoping you measured phase shift at U1 pin 3 and took it to be 60 degrees.
If you are referring to the processing of nulling for best notch depth, yes. For perfect cancellation, the signals have to be equal in amplitude and matched in phase.
But if you're referring to the required precision in the phase shift amplifier, things aren't quite that onerous. The two loops (amplitude and frequency/phase) can still sort things out. It's just preferable that the two balanced demodulators (U2 and U4) operate with reference signals that are 90 degrees offset in phase (in quadrature, in engineering parlance).
I wonder if the frequency switch sections might be out of mechanical alignment.
We know that the oscillator section must be appropriate to the knob indication because you confirmed with a frequency counter. Back in post #55 you found that the notch was way lower than indicated and I recall being surprised it being ~14% off. And now we have phase-shift that doesn't quite compute. The switch decks in the notch-filter are connected to the frequency knobs by shaft couplers. I speculate that the unit-digit frequency switch section might be mis-aligned. ~14% might become ~4%.
Do you recall if you set frequency as 1.0 x 1K or as 10.0 x 100? I suggest trying both settings and measuring ohmmeter resistance between TP4 and U1 pin1. I'm hoping these measurements will reveal resistance at odds with the schematic.
- Design & Build
- Equipment & Tools
- HP 339A oscillator problem
