How would you modify Sony DVP NS900
DIAR said:
I have two outputs in the player and I will put AD8065 to one and OPA627 to the other and plug them both to my preamp. It is easy compare them by simply turning a knob. Eventually I can make the decixcion which one is the best. It is possible that there is no order of superiority and I keep on listening with them both 😀
Are both outputs coming from the same place? I havent got the service manual for this one, but on dvd-ns905, the front out comes from a different dac. Btw, have you measured dc offset before the output capacitors ? If you dont have any dc offset, maybe it´s worth a try to play without capacitors. On my dvd-963sa, this made a big difference (although I got som dc offset :xeye: )
