I just received a 6 position/4 pole rotarty switch from Electroswitch. The model is C4D0406N-A. But the shaft is locked in position, and i cant seem to rotate it. It's an adjustable switch so im guessing its set to 1 position right now, how do i change that?? i tried playing with the washers and nuts on the shaft but with no success...
here is the datasheet:
http://rocky.digikey.com/WebLib/ElectroSwitch/Web Data/C4 Series.pdf
thanks!
thanks!
