How to test JFETs, or any active device
I am doing some time-passing activity but am a little ambiguous about my procedure.
Here I am comparing BF862 and CPH3910, and I have set them up in exact same circuits, with same value components. But this means one device idles at a slight different Id and they also have different gains... Should I adjust values for same Id? Should I adjust values for same gain? If adjusting for same gain, do I add source degeneration, or alter the load on the drain?
I am thinking I can adjust the source resistor for nearly same Id. Then I can AC-couple an amount of source resistance and adjust until the gain is similar for all devices under test.
Or are my values close enough and a few tens of mA wont make a big enough difference anyways?
My intent is to compare and measure gain, distortions, noise, Cin... what else should I add?
For noise tests I intend to simply add series resistance on the input until noise floor rises by 3dB. This is accurate enough? I will be using a 10x and 100x LNA between JFET and analyzer.
Here are some pictures of the circuit and some measurements. I dont know if I ever actually get something sensible out of this.
Oh, I misspelled CPH3910 in many screenshots...
Just adding the shots of my trying to measure input capacitance. I add 200kohms in series with signal gen. This in parallel with the 2megohm gate bleed gives a source impedance of 182kohms.
I then find the C required for the given -3dB cut-off.
I assume 2pF stray cap on the circuit input so subtract 2pF from the calculations.
Comments on this method?
Should I consider the response when using 100ohm as source resistance? (shown in above post)
Edit: I divide by gain to eliminate miller
Anyone know what Onsemi means with noisefigure without stating what impedances or noise levels they refer to? I mean, for noise figure, don't you need the input thermal noise as reference? Any measure given in dB should have what the reference is, no?
