How to Remove Spring Loaded Hinged from Technics SL-D2?
I finally managed to remove them. For someone else who may need to know and for reference. Simply take a screw driver (or even a strong stick object) and from the hole underneath the hinges simply firmly push upwards. This will dislodge the spring hinges and they'll slide out from the top.
Came across your thread which helped me remove my SL-D2 hinge. Do you know where I can source a replacement? One of my hinges has lost its spring tension and that is enough for the dust cover not to stay open.
