I thought about the BIB but I don't like the open top.
That's what grill cloth or similar is for. 😉 Plus, can be used to reduce internal damping for a bit more mid bass 'liveliness' and fine tune it like a vent to get the best overall in room response.
GM
Hopefully one of the 2 optimum Zd will place the driver where they are an appropriate height.
Yeah, that has been the problem with most of the [known to me] floor models and those that did used the ~0.42 offset with one working at the 0.56 offset I used way back when for 8 ft ceilings.
GM
If it is closed at one end so it is a quarter-wave resonator
dave
Apologies thought it was 🙂
This was where I got that info? DIY - Bigger is Better - E J Jordan Designs
Yeah, a source of constant confusion.
All TLs regardless of taper have a 1/4 WL fundamental, but depending on taper can be a 1/4 WL [open cylinder/only odd harmonics] or 1/2 WL [open pipe, closed cone/both even and odd] resonator, so an open pipe and closed cone must be acoustically 2x longer to have the same fundamental [F1] as the open cylinder: Resonances of open air columns
As Jordan notes though, the BIB calculator is intentionally tuned an octave below the driver's Fs. This is to both protect it below Fs and get a bit more LF gain BW to better blend to a typical room's LF acoustics.
GM
I looked at the BIBs and they are too big so I'll continue with the other cabs.
FWIW, if one 'wades' through the thread there's instructions on how to manipulate the Fs, Vas, Qts' specs to make it any size, tuning you want with the understanding that less net volume [Vb] = less LF gain BW and less driver protection down low: https://www.diyaudio.com/forums/full-range/313921-bigger-bigger-badder-bib-2.html#post5571336
GM
GM
Cheers GM
That nice full range diver is probably going to need a very long design. Don't worry too much about he particulars because the driver parameters all have o play together to sound good. I suggest making the cabinet a little big and "mass load" or stuff with fill, cheap fiber glass insulation is fine. That is how I fine tuned mine. Port is big enough to fill after build. Also you can make small slit port at top on one to see if you like I better.I did that and really made a lot of difference. Airy open and not a "boxed in" sound. Good luck. MICHAELI don't know what Mass Loaded means. I appreciate any help you can help with. I'm using full range field coil 10" drivers. The below chart shows how the T/S changes with different voltages.
- Full Range
- How to design a folded Voigt Pipe???
