Currently I am using this circuit to output about 30V each to clean up the output from a dc dc boost converter which is driven buy a couple of 12V/5A walwarts, to drive 2 LM3886s. I use only one transistor (MJE3055 / 10A) and a diode (3A). The output feeds into a LC filter with cutoff of 49Hz. I don't have any startup problems with this voltage. When I get time I will try the same circuit with 58V input and 48V output for about 10A, and we will see if something blows up 🙂
Throwing caution to the wind, eh?
Well, the LM317 might not fail straight away when you do this, giving you a false sense of security. And then all of a sudden boom, there goes the amp...
I think we've given you enough tips, and it's not nice to see them disregarded. Guess you're one of those people who will only learn by hands on experience...
Good luck to you, anyway!
I learn by getting it right.
Some/many claim one learns by getting it wrong !
If one only sees the "wrong" version and never gets to see the correct version, one will NEVER learn !
Iins is obviously a believer in "one learns from one's mistakes".
