Hi All, I am building a RatRod amp with the 6LR8 compactron tube. As you can see by the pix it will be flat black and I will pin stripe it with white and red....just like a RatRod. Anyway, the two outboard holes on the front are for Oil Pressure and Oil Tempature gauges. How can I make those two gauges work as VU meters?????
At first I was going to do that but then realized that this is a RatRod amp and it should have car gauges.
Most car gauges I am familiar with have hot wire mechanisms which probably have too long a time constant to work well for this application. (I could be wrong)
I think taking some meters and modifying them to look like car gauges would work a lot better.
I'd look at Stewart Warner's automotive electric gauges and see if they have anything that might work..
Get some round meters and make new dial scales for them marked "oil temperature" and "turbine inlet temperature" , "EGT", or whatever with green and red segments...
Meter - from Tonne Software
Michael
You could purchase or borrow the Oil Temperature and Turbine Inlet Temperature gauges and scan the faces of the gauges. Glue the scanned images to a couple of VU meter movements.
As for connecting the VU meters, all you'll need is a bridge rectifier (using Schottky or Germanium diodes) fed from the secondary side of your output transformers and a 1k pot so that you can adjust the sensitivity of the meters.
Please share a photo after you have completed the project. It looks good so far.
Nope, no stripes yet. I just now finished all the drilling and whacking and now taking it to Ron's for pin striping.
Thanks all for your suggestions. I really don't care for VU meters, I just thought that since I was messing with it, I could turn the car stuff into VUs. When I get the meters, I see what I can do but it sounds like it might not work as I'd hoped.
Heck, I can draw up anything you can imagine. Let me know if you need a custom meter dial done up (nicely.)
Wavebourn, ... nice. 🙂
..Todd
..Todd
Thanks! 😉
It is a new aggregate distortion measure. 😀
..Todd
thanks for the offer Todd. I will get one disassembled and see what is involved. I kind of like the ** meter.
From time to time i have some comments to be made...in special
when people suggest some awfull modifications to my amplifiers..this meter is wonderfull to be used...the problem is that we should have something alike "bull sheep" or something this way, not to hurt rules...say..if you write bull sheep....everybody will understand (majority) that is not a a real sheep...that is the real sh--... so message is sent without break rules.
I would ask your license, dear Todd, as i want to borrow your image to use it several times, alike a smilie.
Nice...very nice!.... i would never think a better idea.
regards,
Carlos
regards,
Carlos
So do I. Thanks for the inspiration, Wavebourn.
..Todd
That's classic Todd. This might be fun.
This might be fun.
That's what I was thinking. Let me know what your final criteria is and we'll whip something up to suit.
..Todd
Thanks Todd. The chassis is over at a friends for pin stripping. He is a true artist so that means no sense of time. Who know when I'll get it back, but I think if I bribe him with a few beers, I'll get it back this weekend.
I am still trying to figure out how to open the gauges.
Man that's one FUGLY chassis! I like it🙂
Aircraftspruce has instruments from various manufacturers for aircraft, perhaps some of them are usable? (Expencive though).
- Tubes / Valves
- How the heck do I solve this problem????
