Haven't worked with an old transformer like this and need some help to connect it, maybe from German readers.
Primary is easy enough, 8 and 5 for 230V (and a jumper between 7 and 6), but secondaries escape me. As an example it says:
11 . 12 . 13 2x240V (Doppelweg gleichrichtg.)
How should 11, 12, and 13 be connected? And what does this mean:
"Anodenmitte (12) an Masse legen"?
Looking forward to be enlightened!
Ahh, those old elfa transformers !
the secondary is adjutable, note that the midpoint (12) is used in all combination and that the outer pointe are moved to accomodate different values. All of them are for a middle grounded (12) and the "outsides" uses a single diode.
2x240Volt uses 12 to ground 11 and 13 each with a diode to B+
2x260Volt uses 12 to ground 9 and 15 each wih a diode to B+
etc
etc
12 is the secondary center tap (CT). Then you have to select the other two wires for a full wave rectifier depending on your desired DC voltage:
11-13: 480V CT
10-14: 520V CT
9-15: 560V CT.
11-13: 480V CT
10-14: 520V CT
9-15: 560V CT.
"connect the anode midpoint (12) to ground""Anodenmitte (12) an Masse legen"?
When using a rectifier tube with two anodes, these would be connected to for example 11 and 13, and 12 would then be in between the anodes and connected to ground.
OK, now I get the picture. I was hoping to use the transformer in this PSU:
Would it work connecting 11 and 12 to the rectifier?
No, don't do that. Just substitute a pair of diodes for the bridge and ground 12. But be aware that the secondary is only rated for 85mA. That is probably enough for your circuit.
Since the supply voltage is 230V and the transformer primary winding is 220V, my suggestion is:
If C3 uses a 470uF/400V capacitor, do not use a tube rectifier, and I think C7 should use 10V or higher, not 6,3V.
Thanks. I think anode voltage should be 195V in this circuit, if I understand things correctly. Here's a link to the amp with schematic:
http://www.jogis-roehrenbude.de/Leserbriefe/Siemens-C3g/c3g.htm
Any further thoughts would be appreciated.
chising made the best suggestion. Adding to that : replace the B2 with 2 1n4007 diodes. Less complex.
It would work, but then you are only using the part between 11 and 12 of the secondary winding. When you do as chrisng says, you use between 11 and 13, so twice as much. Now the transformer is used more efficiently. But, for a low power headphone amp I guess it doesn't matter much.Would it work connecting 11 and 12 to the rectifier?
- Tubes / Valves
- How should I connect an old tube transformer
