How should I connect an old tube transformer
Haven't worked with an old transformer like this and need some help to connect it, maybe from German readers.
Primary is easy enough, 8 and 5 for 230V (and a jumper between 7 and 6), but secondaries escape me. As an example it says:
11 . 12 . 13 2x240V (Doppelweg gleichrichtg.)
How should 11, 12, and 13 be connected? And what does this mean:
"Anodenmitte (12) an Masse legen"?
Looking forward to be enlightened!
Ahh, those old elfa transformers !
the secondary is adjutable, note that the midpoint (12) is used in all combination and that the outer pointe are moved to accomodate different values. All of them are for a middle grounded (12) and the "outsides" uses a single diode.
2x240Volt uses 12 to ground 11 and 13 each with a diode to B+
2x260Volt uses 12 to ground 9 and 15 each wih a diode to B+
etc
Since the supply voltage is 230V and the transformer primary winding is 220V, my suggestion is:
Screenshot 2025-06-17 at 21-06-35 Scheme-it Free Online Schematic and Diagramming Tool DigiKey...png
If C3 uses a 470uF/400V capacitor, do not use a tube rectifier, and I think C7 should use 10V or higher, not 6,3V.
Would it work connecting 11 and 12 to the rectifier?
It would work, but then you are only using the part between 11 and 12 of the secondary winding. When you do as chrisng says, you use between 11 and 13, so twice as much. Now the transformer is used more efficiently. But, for a low power headphone amp I guess it doesn't matter much.
Right. I was just thinking of getting the anode voltage right, what it would end up with after filtering and resistors (500 + 500 + 6,8K). But I guess the C3g could take higher voltage than 195V as well.
