How can i make Beyers DT990 balanced ?
Tinnitus is irreversible. 😉
Hugo
Glad you brought this up - let's work the numbers.
The DT990 is 96 dB/mW, so at 250 Ohms is 102 dB/ 1V RMS. The Zen Air spec indicates it can deliver at least 6.5V into 250 Ohms, which would be 118 dB SPL. Just a couple of minutes at this volume can damage hearing. If the OP is unhappy with the volume they can get out of this amp then I suspect either they already have hearing damage or the specs are wrong (EDIT: or their source delivers too little voltage to the amp).
jason
Reactions: rayma and Netlist
Its loud . I dont think i have hearing damage. I listen to louder volumes for just 2-3 min. Not maxed out cause it hurts. Then for longee listening knob is at 12 . I just think more power headroom would let me play with my eq more. I have a tube preamp with eq. Connected to the air stack . When i listen a little bit louder and I crank the bass up sometimes it distorts . Like on newer songs most of the time. I dont know why i thought maybe it needs more juice. Cause on the fidelios i can do that no problem and it sounds fine. But beyers cânt do it
Reactions: jasonRF
..luckily just found that thread.
I still have the legacy DT990 with 600 Ohms. Bought back in the late 80'ies^^
its driven now by an Darkvoice 336SE 🙂 (which im gonna swap for an Le Figaro 339i soon)
Now, i like to use it outdoors, with my fresh new bought Samsung Galaxy S25Ultra.
Those new Smartphones sadly didnt have any audio plug anymore...
So i spent the whole night in research..
Maybe, if i am lucky again, i'll get me an KAEI TAP1 Pro one day...
But for now, i just got an offer for an Fosi Audio DS1, which also got an balanced 4,4mm input jack with 220mW(BAL)
and only 120mW(SE) on the 3,5mm single end...
So i just think of MartinX's post, only to change the plug to an 4mm... Cause mine has the 2 cables...
What's the secret for all those new (for me) mobile DAC`s which almost all have those balanced outputs now?
Sorry, but i never saw any headphones even "balanced" nor with an 4,4mm jack -.-
There must be something magic out there, from which i never heard before...
@Netlist don't get me wrong, i do love my fancy DT990! But nowadays it feels a bit like driven an Porsche, but with an SEAT engine, lol...
A little bit of an "fine-tuning" shouldn't be that bad!
And i just revived my little home studio (it was sleeping in an container the last 13 years), with all those BALANCED XLR cables, which i bought this year for the first time (used 6.3mm jacks before^^ And now of that, i felt in love with those balanced things ;-)
Also it`s very hard to find any 6.3mm female to 4.4mm male adapter!
And please, may someone explain me what's exactly the difference between "Gain" and "Power" is?
I mean, it really doesn't matter, which one of those 2 reaches my ears, and give an tinitus..LOL
No, i got my tinitus from from lying 10 years inside an JBL 4520 rear loading horn system, in Frankfurt's (Germany) famous airport discotheque Dorian Gray - Terminal 1, Hall C, level 0, which Sound System was build by Richard Long 🤪🤪🤪
Cheers and peace out,
M;.
