How can I fix my cd player Sony CDP-M26?
Nigel Goodwin said:
It's usually just the small drive belt slipping.
I only see one belt in CDP and it seems ok but ….
The IC appears to be dual operational amplifier, designed for "higher currents" probably around 100 to maybe 200mA to drive the motors. The Vcc and Vee are probably of larger area directly soldered to PCB tracks for cooling. You don’t really need data sheet to fault find - all the values you need are included in the service manual.
Good luck,
Boky
