How better is a Turntable compared to a CD?
I was going to ask, in response to your first sentence, what's the mathematical basis for musical sound (other than what is commonly attributed to Pythagoras).
But it appears you mean "musical sound" to be some metaphysical thing that cannot, even in "theory," be analyzed with science.
The mathematical basis is simply not known because one should know exactly how the human being and his brain work. It is a subject of research but the status is rather primitive in comparison to other sciences. However it is really difficult to imagine how to describe emotions by means of mathematical tools.....
This is the mistake that the neophyte like 45 makes: when 'listening', our brains combine sonic and non-sonic cues unconsciously, along with unconscious biases, to form an impression, but the conscious mind insists that it never happened and ascribes the impression entirely to the sonic cues. The neophyte hasn't learned this yet. He is prone to using phrases like "I trust my ears".
Nothing like this. You are on the wrong way...
In what way is the adequacy of a microphone relevant to your preference for vinyl sonics?
None!
Are there analog and digital microphones (used for recording music) that behave differently? Not that I know of.
No but that's not the point. Recording music doesn't mean that "you have to trust" a microphone. You can listen listen to the recording to make decisions....
The microphone is just a mean not the reference!
Agreed, the days of physical media are behind us.
That is the real reason why analog has improved rather than died! No more mass production except cheap stuff for those who don't care or just want to transfer in some way their records into a digital source not caring about quality.
However it will be different for CD's I guess....
Vinyl playback introduces quite a lot of harmonic distortions.
These result in a measurable lower dynamic range compared to the original. This a.o. means that lower level signals are increased in level. We perceive this as more low level detail.
An other result of these added harmonics is and increase in perceived loudness of the signal. Simple tests verifies this: Listen to a sine wave and a square wave of the same measured level. The perceived loudness of the square wave is a lot higher. Or if you have a synthesizer just turn up the cutoff of the low pass filter and the perceived loudness goes up as the cutoff goes up. Link here: Lowpass Filter Shootout (simple sweeps) | Matttech Modular Demos
So vinyl playback creates the illusion of more low level detail and more loudness/higher dynamic range. But it is an effect.
Digital playback is much more transparent to the source.
See post 2884 of this thread on page 300 where a consumer level showed no audible degradation when inserted into a "relatively high end " LP system.
Clearly you like to wax philosophically more than you like to think through the solution to a problem.
Analog vinyl audio is full of bad stuff. Some people like it that way.
With digital audio, all that vinyl bad stuff is gone. A tiny, imperceptible amount of other bad stuff is added. Some people like it that way.
Problem solved.
No it is not phylosophy it is just a REAL system that you can only dream and not just because of the cost because you can get close without spending a fortune.
Maybe you have problems with this....as already told I also have CD's and use them.
Yes, BUT... The two schools of thought have to meet at some point. They can't be kept completely apart. Say you design hi-fi equipment for a living. The scientific process is your tool, but your goal is to create equipment that appeals to customers on an emotional level enough that they'll buy it.
If you build the gear yourself it gets even more confusing! You wear your technical head when designing it, hoping that your emotional head will like it when you're done.
If you go into the design process with your emotional head on, that is where it goes wrong, you end up spending $100 on a capacitor because the thought of a silver-foil-in-beeswax capacitor makes you feel good, without any evidence that it will have any effect on the sound. In that sense, I think people sometimes fail to keep the technical and emotional processes apart.
All good points, but that only reinforces the need for some clear goals before you start your design process. I mean, you can't get around extensive testing on the bench if you want to design an amp that is claimed to deliver 100W/8ohms with damping factor of 100 and THD below 0.01% at all levels and frequncies. There is still a need to confirm that your amp does it before unleashing it on the public.
Then if your marketing guy wants beewax caps in there because the reveiwer will publish inside pictures in the glossy and beewax caps look great & will sell, all fine and dandy but at the very least you'll want to verify that the beewax doesn't mess up your circuit becaus it has more parasitics than a well-engineered standard cap.
I still maintain that it is better to do the design stuff as much without emotions as possible.
But when listening for pleasure you can cry all you want; I do, once in a while 😉
Jan
This is pretty much hogwash. I do not need to understand the mathematical basis for music to sit in the Amsterdam Concertgebouw and enjoy a great opera.
Likewise, if I faithfully reproduce the air vibrations from the Concertgebouw performance in my living room, I can again enjoy it. All without knowing the 'mathematics of music' - and a lot of other things I have no idea about and are equally irrelevant.
You have a wrong perception of these issues. You are desperately trying to find arguments to support your wrong ideas, but because of them being wrong, you are not succeeding. Doomed from the start - you should have cut your losses earlier, too late now without loosing face...
Jan
I totally agree, but that just begs the question of how you figure out what the goals should be! That is the really interesting part of audio IMO. 🙂
I personally agree with you and Douglas Self, the hi-fi system is for reproducing the original recording as accurately as possible. Modifying the recording to make it sound better is the job of the recording engineers. (And the speaker designer 🙂 )
It was a general consideration about something not necessarily related to music. More likely is nonsense and I agree with you but in general I am not God and you can never say never. It would the end of research....
Jan
Yes you know me.....
Do you want to bet? I am not joking. Then we will see whether I lose my face or you lose your money. Every time I ask this question people run away!
Why? The only response I can give to myself is that people reacting like you are frustrated. Just good for typing behind a screen.
