regulator modification
Gertjan,
You could also try substituting a constant current diode for the resistor feeding the zener. This is a common way of enhancing the performance of regulators.
Regards,
Rob.
Gertjan,
Regards,
Rob.
Re: regulator modification
Hello robert,
like what kind of diode? can an ordinary 1N4001 be used?
Robert F said:Gertjan,
Regards,
Rob.
Hello robert,
A question of regulation!
Hi all,
I have been busy educating myself so I can vote intelligently in the up coming election, I would recommend all do the same. Remember the internet is still mostly free! The stakes are very high! Enough politics, sick of it!
I would recommend doing the regulator with an LM431 replacing the zener as it is adjustable and very quiet. Possibly adding the extra parts on a small piece of perf board with short leads to the UcD. Pay close attention to the 431 app notes! The regulator input cap is a no brainer and doesn’t need to be very large to have a very worthwhile effect. Also follow Chris’s suggestions on bypassing the power pins on the opamp. This is particularly important with fast chips and has a great bearing on the overall sound.
On the cap clamp question, I wouldn’t recommend it. The disadvantages would far outweigh any advantages. It would act like an antenna and this could increase the EMI significantly. It would also require more distance between adjacent channels to prevent heterodyning/whistling.
Roger
Hi all,
Roger
Hi T.
Look what our colleagues at PFM are doing (Andy is there too).
http://www.pinkfishmedia.net/forum/showthread.php?t=26205&page=14
Look at Ron's post #618.
I have mine on the way (I will practice SMD soldering). Appart that, J511 as adviced here and there...and...I found Rubycon ZL 470uF/100VDC. I hope they are because I already bought some:
http://www.referenceaudiomods.com/M...Screen=CTGY&Store_Code=RAM&Category_Code=RUBY
My Autograph enclosures deserve more than stock UCD's 😎
M
Anybody try those LM4562 in the UCD's yet?
M
t. said:Anybody try those LM4562 in the UCD's yet?
I just replaced the AD8620s I was using for the mid and tweeter channels in my UcD triamped system. In every respect I find the LM4562s to sound better. Like most others who have tried this chip, I find there is more detail yet the sound is generally "more relaxed".
LM4562 question
Downloaded the datasheet from National, these chips have fantastic specifications, should be getting close to a "wire with gain".
I have a question regarding the CRD mod and the use of a separate power supply for the op amp. As these things have >100db PSSR even at 10Khz (significantly more at lower frequencies), and the PSSR is similar for both rails, I assume that the CRD mod and having separate power supplies wont make any difference with a LM4562 fitted?
Anyone care to comment on the theory vs implementation?
Regards,
Dean
Regards,
Dean
mac said:
I just replaced the AD8620s I was using for the mid and tweeter channels in my UcD triamped system. In every respect I find the LM4562s to sound better. Like most others who have tried this chip, I find there is more detail yet the sound is generally "more relaxed".![]()
Thanks Mac, I managed to get some and fit them too🙂 Just giving them a good burn in
please report when burned in
Bgt said:
please report when burned in![]()
No problem Bert, one thing I will say is that these op-amps do not need coupling caps, the DC offset on my UCD with LM4562's in and caps bypassed measure less than 2mV on both channels😎
Stevenacnj said:Question:
Are the LM4562s drop in replacements for the AD8620s?
Thanks in advance.
Yes, you need to remove the CRD if its on the -12v supply though
When I look at the datasheet of the LM4562, it looks like the PSRR is best with a +- 15V supply. At that voltage it is the same for + and - rail and below 100dB, at 12V and 17V it is not as good for the + rail. So I guess, for people who want to really get the best of out it need to operate it with a +-15V supply, I assume the rest of the UcD circuit can handle that +-15V as the early UcD versions used a +-15V supply for the opamps. The specs of the lm4562 look truly amazing, what do they cost and where can you get them (online)?
Best regards
Gertjan
Best regards
Gertjan
Hi Gertjan,
I think it should be ok to replace the 12v zeners to 15v on the ucd pcb or just run separate supplys
The LM4562's could be had as samples only from National semicondutor, I don't know if they are available to buy yet.
Be interestig to know what you guys think, I got sick of waiting so managed to get a couple to try myself😀
t. said:
Hi Gertjan,
Yes, was thinking of replacing the zeners or using an external supply. Just need to find a place to get them, guess have to wait a bit until places like digikey have them.
Gertjan
ghemink said:
for people who want to really get "the best of out it"
Best regards
Gertjan
Gertjan all other circuitry supplied with + and -12 Volt is CMOS. In principle it can withstand 15 Volt. A far better solution is to disconnect the original supply from the op amp (as we do in our kits) and supply only the analog input circuit(s) with an external supply. In the latter case the voltage could be + and -18 Volt which gives some extra headroom.
18V is the absolutemaximum rating, which you would want to avoid. It's specified as having a power supply voltage range of +-2.5V to +-17V. Correct me if I'm wrong, but I believe it's wise to steer away from maximum ratings by a fair margin. Apart from that (safemargin), I don't see a reason to go that high since the 8620 with it's 12V supply already has more than enough headroom in this particular application. A more common +-15V seperate psu would be just fine here and leave the option open to try a lot of other opamps as well if you wish.johnrtd said:Gertjan all other circuitry supplied with + and -12 Volt is CMOS. In principle it can withstand 15 Volt. A far better solution is to disconnect the original supply from the op amp (as we do in our kits) and supply only the analog input circuit(s) with an external supply. In the latter case the voltage could be + and -18 Volt which gives some extra headroom.
ghemink said:I assume the rest of the UcD circuit can handle that +-15V as the early UcD versions used a +-15V supply for the opamps.
I failed to mention that my modules are early versions (like yours) and use the 15v zeners without the CRD.
ghemink said:The specs of the lm4562 look truly amazing, what do they cost and where can you get them (online)?
When I called Digikey a few weeks back they had absolutely zero knowledge of this chip. As others have mentioned, if you want them now you have to be resourceful. 😉
- Class D
- Hotrodding the UCD modules
