HornrespMerge available again
I've found a new home for my homepage, http://folk.ntnu.no/bjorkol. This means that HornrespMerge is again available for download. Now that David has included that handy export/import function, it may not be so useful anymore - but it can at least move several records at once (ver. 1.4).
Bjørn
Bjørn
Thanks Bjørn.
Kind regards,
David
Can someone verify that I did in fact get a correctly exported Hyp /.6 expansion.
Or possibly directions on how get a correct export
THANKS
THANKS
Code:
Length (cm) Area (sq cm) Radius (cm) Angle (deg) Height (cm) Width (cm) Width Flare Side Length (cm)
0.000000 260.000000 9.097284 2.495106 16.120000 16.129032 Exp 0.000000
5.080000 273.248840 9.326189 2.665613 16.373923 16.688050 Exp 5.087684
10.160000 287.748650 9.570436 2.840450 16.665197 17.266442 Exp 10.175910
15.240000 303.594873 9.830425 3.019898 16.993949 17.864881 Exp 15.264716
20.320000 320.891813 10.106584 3.204242 17.360460 18.484061 Exp 20.354142
25.400000 339.753327 10.399367 3.393778 17.765157 19.124702 Exp 25.444231
30.480000 360.303566 10.709257 3.588807 18.208602 19.787546 Exp 30.535032
35.560000 382.677800 11.036763 3.789638 18.691495 20.473364 Exp 35.626594
40.640000 407.023304 11.382422 3.996588 19.214664 21.182952 Exp 40.718969
45.720000 433.500329 11.746806 4.209983 19.779061 21.917134 Exp 45.812217
50.800000 462.283156 12.130511 4.430157 20.385766 22.676762 Exp 50.906397
55.880000 493.561245 12.534170 4.657454 21.035980 23.462717 Exp 56.001576
60.960000 527.540478 12.958447 4.892227 21.731025 24.275913 Exp 61.097823
66.040000 564.444520 13.404039 5.134837 22.472346 25.117294 Exp 66.195214
71.120000 604.516285 13.871680 5.385657 23.261509 25.987837 Exp 71.293830
76.200000 648.019541 14.362139 5.645070 24.100203 26.888551 Exp 76.393755
81.280000 695.240642 14.876222 5.913467 24.990243 27.820483 Exp 81.495083
86.360000 746.490413 15.414775 6.191253 25.933569 28.784716 Exp 86.597912
91.440000 802.106199 15.978684 6.478842 26.932251 29.782367 Exp 91.702346
96.520000 862.454084 16.568876 6.776656 27.988492 30.814597 Exp 96.808499
101.600000 927.931298 17.186323 7.085133 29.104629 31.882602 Exp 101.916492
106.680000 998.968836 17.832040 7.404716 30.283140 32.987624 Exp 107.026452
111.760000 1076.034293 18.507089 7.735865 31.526649 34.130945 Exp 112.138519
116.840000 1159.634940 19.212581 8.079044 32.837925 35.313892 Exp 117.252839
121.920000 1250.321068 19.949676 8.434731 34.219897 36.537839 Exp 122.369572
127.000000 1348.689605 20.719586 8.803413 35.675649 37.804206 Exp 127.488884
132.080000 1455.388048 21.523578 9.185587 37.208435 39.114465 Exp 132.610957
137.160000 1571.118725 22.362974 9.581757 38.821681 40.470137 Exp 137.735985
142.240000 1696.643415 23.239156 9.992435 40.518992 41.872794 Exp 142.864172
147.320000 1832.788368 24.153564 10.418142 42.304163 43.324067 Exp 147.995741
152.400000 1980.449739 25.107703 10.859403 44.181183 44.825639 Exp 153.130927
157.480000 2140.599487 26.103141 11.316749 46.154246 46.379254 Exp 158.269982
160.000000 2225.000000 26.612769 11.549754 47.170000 47.169811 Exp 160.820795
I did
S1 260
S2 2225
go to L12 press H to get Hyp, enter 160
T .6
Those are the inputs, but what I need verified is that HR will actually export the data for that correctly because the export options are Con Exp and Uni? Specifically the field that needs to be accurate is the Area field.
S1 260
S2 2225
T .6
Well if it makes you feel any better I got exactly the same results. If you want pics I saved them. But my guess is you can look at the input screen and the data just as easily as I can. You have worked this out well.
This looks like a wave guide rather than a horn.
Mark
Mark
In the Export Wizard, you can select the Width Flare as Con, Exp or Uni. That means this is the way the width of the horn varies, not the area. Plot the height and width contours in exel or similar, and you will see how it works.
Bjørn
Hello,
Elias did a wavelet analysis in order to compare the Impulse Response calculated using Hornresp and the Impulse Response I used to measure at home on one of my horns (Le Cléac'h, Fc = 320Hz, T = 0.707).
The graph where the 2 are compared is at:
http://www.diyaudio.com/forums/atta...-horn-honk-wanted-le_cleach_j321_wavelet2.png
It is taken from a discussion about horns and honkness, see:
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-19.html#post2118791
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hi Jean-Michel,
Thanks for the comparison, and for the link. The "Horn Honk" thread is very interesting indeed!
Kind regards,
David
Hornresp Version 26.30
Hi Everyone,
Hornresp Version 26.30 has just been released. The following changes have been made to the Horn Segment Wizard:
* The operation has been standardised for all flare types.
* Some of the less practical oblate spheroidal waveguide options and associated picklists have been removed to simplify matters, and the AT parameter is now more completely integrated into the tool.
* There is no longer a separate 'Specify' option for AT - the various 'Calculate' options now cover all permitted input combinations.
Kind regards,
David
Hi Everyone,
Kind regards,
David
Hi David
You appear to be putting a very fine edge on your software tools. It will indeed make things work to their full potential. It is getting more a more interesting what can bee successfully simulated. And the the accuracy of the simulations is great. Many thanks for your very thorough commitment to the excellence of your program.
Mark
Mark
It just keeps getting better.
Hi Mark and brsanko,
Thanks for your kind words. As you have probably gathered by now, I am a bit of a perfectionist - it can be a real curse sometimes .
Kind regards,
David
Ain't a d@mn thing wrong with that! We're just lucky that you are!
Help a new user
Just downloaded and trying out. I entered all my S values, but it says error L12=0 and will not let me change any L value.
Also, I need to understand how to enter driver parameters.
Specifications: *Power handling: 200 watts RMS/400 watts continuous program *VCdia: 2" *Le: 0.8 mH *Impedance: 8 ohms *Re: 5.1 ohms *Frequency response: 70-4,000 Hz *Fs: 70 Hz *SPL: 97 dB 1W/1m *Vas: 0.6 cu. ft. *Qms: 3.7 *Qes: 0.21 *Qts: 0.20 *Xmax: 6 mm *Dimensions: Overall diameter 8.8", Cutout diameter 7.4", Depth 3.7".
HR needs Sd, Cms, Mmd, Bl, Rms, Nd
Only Re and Le given in above. I guess I need formulas for figuring what HR needs?
- Subwoofers
- Hornresp
