panomaniac said:
And that comes with what? Experience.
(but teaching can jump start it)
You also have to question. Don't take experince as golden, it can be a bad experince. You have to learn to look for good data and to throw out the bad data. All data is not good data just as all experince is not good experience. There is very little "conventional wisdom" in audio that I use and almost noen that I trust.
panomaniac said:
Question is: Once you have the polars, what do you do with them? But that's for another thread.
Its not hard - look for consistancy of response. Why should an off axis response not be as flat as the on-axis response? The power response in a room is extremely important and much of what we hear is from off axis.
gedlee said:Its not hard - look for consistancy of response. Why should an off axis response not be as flat as the on-axis response?
Uh, yeah. Sorry. I was thinking about cone drivers for some reason. Pretty silly in a horn/waveguide thread!
FWIW, I built a pair of 8 sided Tractrix horns. Cut-off at ~500Hz. Nice sound, no real nasties - but they beam like crazy. Easy to see why some much work goes into CD horns.
pooge said:What are the two ESP12 graphs about? Why is one showing an axial hole while the other doesn't?
They both do, apparently. It's partially EQ'd out at 7.5° in the second one.
I assume this is the reason Earl cautions against equalizing the ESP waveguides flat on-axis....
Hello Earl
Can you post the impulse plots or a CSD so we can see the differences in the time domain caused by the difraction compared to your wavequide?? Would HOM show up in these plots??
Thanks Rob🙂
Thanks Rob🙂
Earl:
Sorry I may have missed this in an earlier thread but is there a way for a DIYer to buy the waveguide in the ESP 10/12/15? (other than buying the entire speaker!). If not are there any waveguides out there you could recommend?
No surprises here but that nasty on axis hole from your horn Gedleel. How do you 'listen' around that?
holdent said:Earl:
If you look over at Vendors Bizzare you will see that I am selling the waveguides for the ESP10.
Magnetar said:No surprises here but that nasty on axis hole from your horn Gedleel. How do you 'listen' around that?
I don't sit on-axis.
Absolutely. Eqing to a flat axial response would be a disaster.
I used to EQ to try and minimze this hole, but then it dawned on me - "why bother!" The axial response is virtually irrelavent, unless you sit on axis, but I don't recommend that as I have discussed so many times before. Since no one is ever on-axis in my setups why worry about it. As far as the power response goes the axial response is irrelavent.
So I suppose the poor fellow using the JBL horn can say he doesn't lay on the floor or stand above his speakers.😉
Well, not within the first couple of feet of them, no.Magnetar said:So I suppose the poor fellow using the JBL horn can say he doesn't lay on the floor or stand above his speakers.😉
If we want plenty of artificial ambience and early reflections off the floor and ceiling, we use the symmetric 100° x 100° version.
It's rather simple geometry, actually, this controlled directivity thing.
Speaking of which, one might review Gedlee's paper recommending that the first reflection should come from the OPPOSITE sidewall, requiring that the speakers be toed-in in a normal listening environment, and placing them more on axis with the listener....
ZilchLab said:Well, not within a couple of feet of them, no.
If we want plenty of ambience and early reflections off the floor and ceiling, we use the 100� x 100� version.
It's rather simple geometry, actually.
Speaking of which, review Gedlee's paper recommending that the first reflection should come from the OPPOSITE sidewall, requiring that the speakers be toed-in in a normal listening environment.... 😉
The JBL horn was designed to do what it does. Different geometries for different applications.
If the Gedlee speakers are toed in like you say then they will most certainly be on axis most of the time if not all the time -The opposite of what gedlee just said - so which way is it?
Seems to be a contradiction here. If they're toed in, then they're not on axis.
Seems to be confusion here, is what.FrankWW said:Seems to be a contradiction here. If they're toed in, then they're not on axis.
Magnetar is correct: If they're toed in, they are more on axis with the listener, who is presumably midway between them at some distance back....
If the speaker has a consistent off axis power response, why would you want to sit at the apex of the triangle formed by the axes?
Seems to me more sensible to position myself beyond that apex.
The idea is to have a wide sweet spot, no?
The on-axis response for the ESP12 doesn't matter because it's such a tiny part of the soundfield radiated by the speaker... suppose the hole is there for a 5 degree cone... that's only .2% of the area sound is radiated into, and, approximating the soundfield by a 90 degree cone, that's about 1% of the radiated sound. However, the response of the JBL at say 45 degrees off axis is hugely important because it's a major part of the soundfield radiated by the horn.
FrankWW said:The idea is to have a wide sweet spot, no?
I would say no, the idea is to have the response radiated at all angles, which constitutues the direct sound, early reflections, late reflections, and power response, which together determine the tonality of the system, flat and smooth. The direct sound, while important, is only part of the equation.
I only listen on axis, minus a few degree...speakers pointing to the back of the head
yes I know its in the crossover, but I think that listening off axiss is cheating
fizzard said:Could you not also lean them back? Is the radiation pattern cylindrically symmetric?
Listening with extreme toe in sitting back tends to present other nasties - excessive cross talk (cancellations) between channels - yech
Tilting them back seems like a better solution as long as you don't stand up and listen.
Another thing you have to remember is the on axis energy is the highest (like most loudspeakers) and in this case the most non-linear.
- Horn vs. Waveguide
