Horn loaded dome midrange
Goto used to have Beryllium which is fairly radioactive and expensive.Then their units are rated to 5 W (not 120 W PMPO) which is fair when played in a room with boundaries not too distant. We're talking about efficiency and polar dispersion , better with no compression when hearing at high volumes . Never heard nor GOTO nor CD in my room,I prefer to watch the photographs!
Don't want to mislead you into thinking you get something for nothing. Like I said, the RS52 is great for the price...but it is not in the same league as a good compression driver with substantially more diaphragm area.
I also said the RS52 might make a good candidate for a (quick opening) constant directivity conical waveguide...but you are suggesting a variable directivity device with relatively slow throat expansion. Personally, I haven't had much success with domes in "tight" horns...they may be a better match with compression drivers.
Along with your other system objectives, you need to decide the polar pattern you want (should complement the woofer and tweeter). Polar pattern will help guide flare selection. Flare selection can influence driver selection etc etc. You have probably heard it a hundred times, but it's all about balancing tradeoffs.
10 db sensitivity gain, not to bad... 🙂
Now to find a midrange dome which can be used without a tweeter... If it had not been for the 14khz breakup of the Dayton it could be an alternative.
I like the idea of a driver with 500 to 20 khz bandwidth and with the dynamics of a compression driver, yet the smoothness of a dome tweeter.
4" dome - reversed 2446 without phase plug and rear cover.
working above 400 hz to xxxx
Maybe this one? With some eq over 10 khz it could work fullrange? 🙂 And I could just use a single cap at 10 khz or so to deal with the horn boost. Not to mention it would make for a very simple crossover with a well behaved woofer.
