I'm sick, couldn't be bothered searching, or modeling it myself, so.. has anyone done a horn loaded brahma? I was thinking the 12inch. We all know how inefficient the drivers are, but are apparently very high SQ, so, is a horn a good idea? 🙂
seeyas... thanx
seeyas... thanx
Why should I be bothered modeling it up for you since it takes ur fancy todayI'm sick, couldn't be bothered searching, or modeling it myself
haha
Depends what yuo want it for
It seems to want an extremely high compression ratio which isnt good. Just use two of what u have already 😉
Wired in series it goes fine.
155cm - > 2400cm 299cm expo 18L vrc 1pi
mike.e said:Wire it in series
the 12inch?? as if it would make that much difference....
The smaller the membrame, the longer the horn needs to be to get low. If you use 12" or smaller membrames, use multiples for bigger Sd or don't expect much low end in an one-person-moveable enclosure.
Mvg Johan
Mvg Johan
Rademakers said:The smaller the membrame, the longer the horn needs to be to get low. If you use 12" or smaller membrames, use multiples for bigger Sd or don't expect much low end in an one-person-moveable enclosure.
Mvg Johan
Oh im well aware of this 😀
http://www.diyaudio.com/wiki/index.php?page=basshorn
No point! The twelve is powerful enough or,or using two would ensure insane results. People just need to realise huge path lengths will be required.
It would be smaller with huge SPL hehe, I wonder how a really long throw driver like that will look in Hornresp or something similar.
it looks 'normal'
it just doesnt bottom out so easily.
More important are the t/s parameters
From memory,double xmax equals only 6db more output which is a perceptible increase but not amazingly blowing ur mind more output
why horn an 18"???? unless u have the room for it! i just have enough room for my 35hz basshorn im building for my room! i have to re-arrange everything tonite for it 😛
cant wait till it's built! DRUM AND BASS ALL THE WAY!!! sorry to my nieghbours, but they will be deaf after i give my basshorn a good burst with some bass!
- Subwoofers
- horn loaded brahma?
