Hole Saw or Router
A floorstanding drill press is nice but a bit unwieldy, and not a must-have for "light" work. I have a tabletop model which I mounted on an Ikea "Vika Fagerlid" table foot with heavy bolts 😉 The result is in the photo below.
Kenneth
And if it's a thu-hole, you can use a hack saw blade (and more skill) to get nice sharp corners.
When I did notched diamond inlays in my recent pool cue build, I used the CNC mill to make the pocket and then cleaned the corners with an x-acto knife.
