I used to cut front baffles on my CNC mill. Any shape hole I wanted with accuracy to 1/1000th of an inch. Not bad for wood work.
That's definitely the way to do it if you can!
"It is so choice. If you have the means I highly suggest picking one up."
-Ferris Beuler
It's all cool. Anyone reading this thread will get more than they bargained for in information!😛
I have a tabletop model which I mounted on an Ikea "Vika Fagerlid" table foot with heavy bolts 😉 The result is in the photo below.
Kenneth
IKEA supports DIY audio in SO many ways... Good to see everyone getting creative out there!🙂
Can a CNC machine cut perfectly square inside corners, or only rounded?
Kenneth
Limited to the radius of the cutter.
For SHARP corners, you need to use a chisel (and skill).
True. You can get cutters as small as 1/8 inch which doesn't leave much material to remove.
And if it's a thu-hole, you can use a hack saw blade (and more skill) to get nice sharp corners.
When I did notched diamond inlays in my recent pool cue build, I used the CNC mill to make the pocket and then cleaned the corners with an x-acto knife.
- Design & Build
- Construction Tips
- Hole Saw or Router
