How about the PY 500A
Used as Horizontal Efficiency diode in many old British/European TV's--Usually easy to find, and reasonably priced NOS........
As I recall, the PIV is 2.5KV, with anode 500mA More than enough for your PSU.
Drawback is the heater volts around 36 if I recall correctly! Are you thinking Bridge or half bridge rec?
