High quality Raspberry Pi 24bit/384k I2S card
Good point, two answers. First: because it's fun, and having multiple channels out of a sub €20 euro SBC like the Zero 2 coupled with a sub €5 like the Pico is enticing. Second: all the SBCs that support multichannel audio on paper seem to have issues when actually trying to make them work. The RPi5 does not support multichannel audio on paper (by the datasheet, I mean), I do not know of recent developments finding a way to achieve that somehow, there are lengthy threads on various forums but I've not seen a canon solution (but I also admit of getting tired after the fist few pages of the threads). But the RPi5 is far too expensive anyway, so...
I did not check the Radxa Pi S (I gave a look at the Rock 3c, actually), I do not understand your reference to the USB max current, are you suggesting some kind of USB-I2S solution? But in general, if you know about a cheap SBC that actually supports multichannel audio, I'd be glad to hear from you.
Progress report: kernel patched (the old patches by @olo111 do not work anymore, but provided a good staring point) and I2S@384k works just fine on the Zero 2, by my limited testing. Now I'm waiting for the Pico to arrive and we'll see if 1 I2S @384k -> 2 I2Ss out @192k is indeed possible.
Why all the hassle of hacking the stereo I2S to multichannel with extra CPLD/MCU, instead of using any of the other ARM boards with proper native multichannel I2S? Either the hungry but performant RPi5, or other boards happy with the 500mA max from the USB-device port (e.g. Radxa Pi S).
Indeed, RPi5 can output up to 8 channels.
The basic idea is to use a RPi Zero 2 with CamillaDSP ingesting the source (via USB), implementing the filtering stage, and outputting the 4 channel resulting signal as a multiplexed i2s@384kHz.
So you want to feed 2ch digital via USB, do DSP on RPi and then output 4 channels?
Just FYI, York can do that thru one usb, up to 384kHz for 4 output channels: https://www.diyaudio.com/community/...tichannel-input-output-interface-york.413504/
Good to know. As written in my previous message I kinda got lost among the various threads on the topic. If you can share a specific pointer to a post/thread addressing the issue I'd be grateful. That been said, again, the RPi5 is overkilled for what I need to do.
That's right. I guess I might add lossless bluetooth later, but for now: USB it is.
Yes, I know. But the ultimate goal is to have a smartphone room correction app that sets up the filters to be used, so I need more control on the DSP stuff and a way to remotely update the filters from the app. Which means I need the RPi.
I see. There is some discussion:
https://www.audiosciencereview.com/forum/index.php?threads/8ch-hifiberry-hat-dac-for-rpi5.53672/
Yes, the RPi will be needed anyways. That is just an interface, not DSP.
How do you plan the app implementation?
Yes, it's way too expensive and power hungry for a USB-multichannel I2S bridge with some reasonable DSP capabilities.
E.g. https://www.audiosciencereview.com/...d-direct-vs-any-dac.55386/page-6#post-2024214
https://shop.allnetchina.cn/products/rock-pi-s?variant=32279981490278
Many non-RPi ARM SBCs support proper 8ch audio, some 8+ch.
Reactions: eclipsevl
Basically a simpler version of https://housecurve.com/ (stealing code here and there from Open Sound Meter) that can upload the filters to the RPi. But that is a very long shoot from where I'm at now, if I was retired that could be achievable in a reasonable amount of time...
However, the rest of the setup (minus the app, I mean) is actually achievable.
Thanks. I see your chain includes a "I2S out @384/32/16ch" step. Is that an I2S/TDM signal available on some header pin? Have you been able to activate it with just some DT fiddling or is it more work than just that?
Update: I see here https://wiki.radxa.com/RockpiS/hardware/gpio that there are exposed GPIO pins for I2S0_8CH, which is great. But the overlays published on the same pages do not include anything I2S related...
Many non-RPi ARM SBCs have horrible support, with producers publishing kernels patched by copycatting code from around the net. I spent my spare time of the last week trying to make the I2S out of an OrangePI Zero 3 work.
At the end I've been able to do it (minus MCLK that I couldn't fix and that I needed). But I had to patch the kernel, mess up with the DT, all to get back to where I stated from with the RPi Zero 2 which, at least, has a community that can help...
Yes, but the S version outputs/inputs only 8ch. The S core module has all 24 I2S I/O channels available.
DTS is standard method of ARM kernel configuration, no way to avoid that. I have also modified kernel (e.g. raised samplerate limits to test real capabilities of the I2S interface) but that's not required.
Yes, if the feature is actually documented. In fact the level of detailed documentation for RPi is way below many of ARM boards which often have complete schematics and detailed SoC technical specifications available. Yes, it takes kernel effort to make features work as required, it's normal.
DT fiddling is expected. The point is: are the DTSs available or it's a work of patching up various almost-but-not-fully working versions popping out in forums and github repos?
I have my eyes on the Zero 3W now, it should have three I2S devices available, that would mean I could also input one I2S from a bluetooth adapter. If only I was sure that the DTSs to enable the three I2Ss and the USB UAC input are easy to find... I will ask on their forum, we'll see if they know their own stuff.
Since I need mainline latest for driver development, my situation was always much more complicated. But if you want only working features, it's typically not that difficult and radxa-provided kernels require only DT overlays. Also their forum is quite active, I use it quite often.
Hm, did you look at Zero 3W schematics? I cannot find 3 complete I2S interfaces being available on the SBC pinheader - one hooked to the internal BT chip (do you need your own?), another hooked to the internal codec. But I did not study the schematics thoroughly.
Typically if multiple interfaces are needed, the core boards are required (RK3566 is very popular and many SBC vendors have a number of core variants with RK3566). Core boards have many pins, of course require a custom IO board (but that's expected if a complex solution is being developed).
I'm not myself a big fan or RPi's stuff but, taking the Zero 2W I'm working on as an example, the schematics are available (https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#raspberry-pi-zero-2-w) as well as the SOC Datasheet (directly from Broadcom).
On the contrary, I'm having a lot of issues on the software side of things with Allwinner's SOCs. Maybe Rockchip is better in this regard.
SBCs manufacturers really just "dress up" distributions with a small personalization layer on top of SOCs' makers "official" kernel distributions...
And they said it could not be done 😛
Works just fine, tested with 4x96 kHz, only because I do not have 192kHz DACa at hand.
I assume 8x96k is reasonable and 8x192k possible. But this stuff needs a lot of polishing (a kernel driver in place of the kernel patch, a proper ALSA device in place of the user-space virtual card I set up now and so forth).
Also consider that this stuff is fully synchronous, no jitter to speak of. The signal out of the logical analyzer is as clean as it gets.
Not bad for a €15 RPi Zero 2 and a €1.5 Pico...
Reactions: rockies914
The PIO stuff on the RP2350/2040 is indeed interesting. I am using it for several SPI custom thingies. It is rock solid on timing. One suggestion though, make sure you have a digital scope. Capturing the PIO outputs is almost a must to see what is going on. The statements are very succinct, but can do things you don't expect. One thing I saw was the conditional jmp instruction is prone to transient pulses, while the wait is solid. Note most of the conditional jmp's are commented out as they were getting triggered by noise. And unfortunately, the conditional jump must always be on the same pin, in this case it is controlled by CS. The sideset is fantastic for debug with a scope. You can use the sideset to see the timing of the program. Programs are quite short. Below is the one I use to make the RP be a SPI slave.
flush:
mov isr, null side 0 ; Clear ISR and input shift counter
set pindirs, 0 side 0 ; disable TX
wait 1 gpio 11 side 0 ; wait fror data rdy before we consider CS
wait 0 gpio 12 side 0 ; wait for CS to go low
set pindirs, 1 side 0 ; enable TX
set x, 31 side 0 ; 32 bits per word
set y, 3 side 0 ; 4 words to transfer
loop:
out pins, 1 side 0 ; push out the TX bit
; jmp pin, flush side 0 ; Bail out if we see chip select high
; wait for clock hi to sample
wait 1 gpio 13 side 0 ; sample and rise autopush takes care of FIFO's on boundary delay 2 cycles since we are @125MHz
in pins, 1 side 0 ; sample RX
jmp x-- do_next_bit side 0 ; keep looping until 32 bits sent
set x, 31 side 0 ; reset the bit counter
jmp y-- do_next_bit side 0 ; Loop if we are not done with the 4 words
stall:
jmp stall side 0
do_next_bit:
wait 0 gpio 13 side 0 ; wait for clock to go low
jmp loop side 0
In my case I'm using the RPi as a clock slave. All the clocks are provided by the Pico and all the PIOs in the Pico run synchronously at the same clock rate (8 times the BCLK of the input I2S signal, I could probably make it work at 4x but I didn't bother). It's all managed by PIOs and DMAs, no CPU whatsoever. And the system clock (used by the DMAs) is an integer multiple of that of the PIOs, just in case...
All this stuff introduces just 4 frames of delay (that's about 10 microseconds).
To be clear: this thing is not meant to be a generic solution. My goal is to be able to output 4 channels from CamillaDSP for a pair of active speakers.
