Small O/A diameter requires small core diameter.
Maybe they have used the steel core to retain sufficient handling strength.
Check the resistance for your typical interconnect length. If it's under 0r1 then you can safely ignore it for all normal audio operation, where typical source impedance range from 10r to 1000r
I've used a piece of a USB cable in a pinch and it works just fine. I ignored the two tiny signal lines and used the two heavier power conductors for the signal. Grounded the drain wire from the woven shield at one end. No $$$ (got dozens), low resistance and plenty flexible.
- Design & Build
- Construction Tips
- High quality coaxial for internal signal wiring
