high excursion drivers for sealed boxes
just wondering if anyone can tell me if there is any ultra excursion driver (with MORE than 1.5 inches of peak to peak excursion) designed for SEALED boxes and is available for consumer purchase internationally (dont mention any driver for ported boxes). (The NHT/Shiva/titanic,etc does not qualify)
[Edited by pkgum on 11-23-2001 at 12:41 AM]
Pkgum, this probably isn't what you want to hear but I prefer to use multiple drivers, (12") rarther than expect linear action from one driver. Oh and yeah, big boxes. It's an option, but as I said probably not the one your after.
Regards WALKER
walker....one high excursion driver in a smaller box is much more cost effective than multiple drivers in a larger box(s). mulitple drivers do sound better though.
besides, the sub looks cool with that cone moving backwards and forwards at amazing distances...group delay? theres not much group delay in a quality driver in a proper box..especially in a sealed box.
PJ
the ACI 10 only has around 25-30mm peak xmax. Im looking at the 40mm+range. The SHIVA,ACI,TITANIC,NHT1259 might be popular...but lm looking at drivers at a much larger scale.
note...im building a ported sub using the BP1503 driver. If anyone knows the BP1503, im interested if a sealed design of that scale is possible or not.
it is possible...but they dont go very low...just look at one example..the paradigm servo 15...it manages to go down to 17Hz!!! in a sealed box...how did they manage to achieve that?
http://www.paradigm.ca/Website/SiteReferenceProduct/RModels/Servo/ServoSpecs.html
the BP?
at 50Hz it is 117Db
at 30Hz it drops to 110Db
at 20Hz it drops to 106Db
at 18Hz it is at 104Db....a ported design using this driver can put out 30Hz at 112Hz and 18Hz at 112Db!!
Thats why it is really only suited to ported designs
by the way..how do manufacturers measure freq response?
gum
the BP?
at 50Hz it is 117Db
WRONG.......
You said you were going to buy Vance Dickason's "Loudspeaker Design Cookbook". Did you?
Nisbeth, PKgum wants more than 1.5" excursion, the peerless drivers won't go that far unfortuneately. I am about to use a XLS10 4ohm soon for a freind and wouldn't mind the benefiet some others experience with it, but this is't my thread.
Regards WALKER
I ran the Blueprint 1503's numbers-those provided by the DuMax test Thomas W printed on this thread: http://www.diyaudio.com/forums/showthread.php?threadid=999
I got pretty much the same results as gum. At 18 Hz., in a 3.25 cu. ft box, the 1503 will be putting out about 104 dB at 1000 Watts input, or 107 dB at 2000 Watts input. The 1503s are rated for "1000+" Watts, but there are always instantaneous peaks.
A ported design would work better. About 6 dB more output in the same size box.
For what it is worth, the low final Q-about .5 in a 3.25 cu. ft. box--will give extremely undistorted bass-very fast and quick. Some loudspeaker designers design their sealed boxes for a final Q of about .5 for that reason. So it would be wrong to say that the 1503 cannot be used in a sealed box of that size.
But you will get more output from a ported box tuned to 18 Hz.
At 16 Hz, "room gain" amounts to about 9 dB, so it should be very close to that at 18 dB. This would bring the output at 1,000 Watts up to 113 dB or so at 18 Hz. for the sealed box.
I have heard mention that a low Q sealed box-which this 3.25 cu. ft. box is-merges into room gain better than a ported box, but I am unfamiliar with any details of that theory.
[Edited by kelticwizard on 11-24-2001 at 12:11 AM]
Tom Nousaine frequently says
"Sims are for show, 1 meter ground plane measurements are for go"
People can 'bench race' computer models till hell freezes over. But until you actually build something with one of the new high excursion drivers it's all just speculation.
The BluePrint 03 drivers will work fine in sealed enclosures. The 1203 for example can be used in a box as small as 33L and won't need Linkwitz-Transform circuit to get a relatively low "Q".
[Edited by ThomasW on 11-24-2001 at 11:48 AM]
those statistics came from a custom design in unibox with guessed Vb(cant remember what I put in..i think the qtc was around 0.5) at 1000W power...but they were just there to show that BPs in a sealed box have much less ouput than in a ported box
you guessed right...i didnt buy the book..i went straight to building...as you had said, the posted info is enough to get me going....book later
can someone answer this...
How do manufacterers meaure freq response?
gum
Mfgr's should be publishing 1 meter anechoic FR plots.
Regarding the Servo 15, if you want to copy one then just use a 1503. You must add an appropriate custom LT circuit, have a big amp and tons of EQ. That's what the mfgr's are doing that use 15" or 18" woofers in tiny boxes. Servo circuits are also helpful when cramming drivers in boxes that are too small.
Understand is that generally speaking servo designs, and designs placed in too small a box, EQ'ed with LT circuit and other hardware, won't play especially loud. Most of them will go fairly deep, but again there's not much software out there containing info below 18-19Hz
Ignite:
If I understand you correctly, one would be going in toward the box while at the same time, the other would be pushing out.
I believe they would cancel each other. It would be like eliminating the box entirely and just having two unenclosed speakers in a room.
kelticwizard,
in theory that is how it works because in theory the air pressure inside the enclosure remains constant but in practice it varies quite a bit....... this occurs because the compression caused by the driver whose cone is moving into the enclosure IS NOT EQUAL to the rarefaction caused by the driver whose cone is moving outward.
Such are the joys when working with air which is inherently single-ended.
There's a new candidate coming out soon from Adire.
The Brahma, available in 10", 12", 15" and 18" starting in december.
The 12" offers 1600W RMS power handling 27.32mm one way xmax (DUMAX) and specs similar to other insane-excursion drivers.
http://www.adireaudio.com/cd/brahma_series.htm
Personally I'm not a fan of these drivers. Higher FS than conventional subwoofers makes them useless without EQ and thus extremely inefficient. I prefer a larger box, maybe multiple drivers, if it's not so power hungry. But that's just me.
Ignite, you're half way to an isobaric enclosure, but missing one box.
What you will get is a lot of cancellation at low frequencies, (which is about everything a sub puts out). Also a good chance of damaging the drivers if they pole, (that is the voice coil or cone hit the magnetic poles, OUCH).
Definitely not a good idea.
Regards WALKER
Ignite:
The new Brahma seems to be 3 dB down at 19 Hz in a 3 cubic foot box tuned to 19 Hz. Granted, the speaker is only 84 dB @ 1M/W. It still looks like a good subwoofer in a very compact box.
[Edited by kelticwizard on 11-26-2001 at 11:57 PM]
